Ana içeriğe geç
Sony Cyber-shot DSC-HX80 LCD Screen Replacement
Neye ihtiyacın var
  1. Sony Cyber-shot DSC-HX80 LCD Screen Replacement, LCD Screen: adım 1, 1 resimden 1.
    • Before disassembling any part of the camera, turn off the power by pressing down on the ON/OFF button. The ON/OFF button is located on top of the camera.
  2. Sony Cyber-shot DSC-HX80 LCD Screen Replacement: adım 2, 1 resimden 1.
    • Open the compartment located at the bottom of the camera. Slide the LOCK/OPEN switch to the OPEN side. Locate the small blue tab on the side. Pull it in direction away from battery. Remove the battery and set it aside.
  3. Sony Cyber-shot DSC-HX80 LCD Screen Replacement: adım 3, 2 resimden 1. Sony Cyber-shot DSC-HX80 LCD Screen Replacement: adım 3, 2 resimden 2.
    • Flip LCD screen upwards.
    • Use the PH000 Phillips head screwdriver to remove the two 0.3 mm Phillips black screws located on the sides of the LCD screen. Place screws on magnetic mat or plastic bag.
    To complete this repair, I need the connecting piece behind the LCD. Do you have that piece if not wjere can Iget it or canyou get it for
    Frank Mohammed - Yanıt
    To complete this repair, I need the connecting piece behind the LCD. Do you have that piece if not wjere can Iget it or canyou get it for me
  4. Sony Cyber-shot DSC-HX80 LCD Screen Replacement: adım 4, 2 resimden 1. Sony Cyber-shot DSC-HX80 LCD Screen Replacement: adım 4, 2 resimden 2.
    • Use the PH000 Phillips head screwdriver to remove the two additional 0.3 mm black Phillips screws located on the top edge of the LCD screen. Place screws on magnetic mat or plastic bag.
  5. Sony Cyber-shot DSC-HX80 LCD Screen Replacement: adım 5, 3 resimden 1. Sony Cyber-shot DSC-HX80 LCD Screen Replacement: adım 5, 3 resimden 2. Sony Cyber-shot DSC-HX80 LCD Screen Replacement: adım 5, 3 resimden 3.
    • Use a nylon spudger to gently remove the damaged LCD screen off the camera.
    • Replace LCD screen with new one.
    What is the black paper/plastic like strip at the bottom connecting the flip up part?? Mine detached from my camera and now the screen is black. Is that fixable?
    Brittani - Yanıt
    Whst is the name of the connecting ribbons piece at the back of the LCD. On my camera ..Sony hx 80, the end of that piece that connects it to the camera is broken. Do you have that part? If not, where can I get it..reply to….frango@rogers.com…I am in Canada. THANKS.
    2 more photos showing the removal of the cables and then their reattachment would earn the author points.
    Randy Post - Yanıt
    I agree, this how-to is skipping the hard part. Just busted one of the ribbon cables 😔
    Mike Millis -
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Gordon Jones
1.081 İtibar
5 adet Kılavuz yazıldı
Ekip
7Kılavuz Yorumları
You should note that there is a small rectangular magnet (perhaps 8mm long and 2mm across) that has to be placed at the top of the LCD directly under the flash switch. Otherwise the LCD image will be upside down.
Dale Bjerning - Yanıt
Hello could you show a picture of where exactly under the flash has to be the magnetite tangle. Thanks.
Wolfina -
Anyone know where I can find the cable from the screen to the camera?
Thorusofer Dragon Knight - Yanıt
same question here! i repalced the lcd thinking that was the problem but the lcd is still black. the viewfinder works fine so i think i need to replace the cable that goes from the camera to the screen. any info?
Facundo V -
where can i find the screen other then threw sony
ninjadawn25 - Yanıt
Im looking for lcd screen for sony dsc hx80 on back TX08D155HMOAAA. A9N9I523946
Kaz Balcerzak - Yanıt
Looking for replacement lcd screen fo sony dsc hx80 screen # on back is. TXO8D155HMOAAA. A9N9I523946
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 11
Son 30 gün: 91
Her zaman: 3,973
