Ana içeriğe geç
Sony Cyber-shot DSC-HX90V LCD Replacement
Marin Rusinov
Marin Rusinov ve 3 diğer katkıda bulunanlar
En son December 29, 2021 tarihinde güncellendi
20 dakika
Orta
İşlem Görüntüleri
This guide will teach you how to remove and replace the LCD. The guide has nine steps and will take time to complete, but each step is relatively easy since the guide requires no advanced techniques.
Neye ihtiyacın var
Aletler
  1. Sony Cyber-shot DSC-HX90V LCD Replacement, Button board: adım 1, 1 resimden 1.
    • Place the device so bottom of the camera is facing up .
    • Remove the five marked screws with a Phillips #000 screwdriver.
  2. Sony Cyber-shot DSC-HX90V LCD Replacement: adım 2, 1 resimden 1.
    • Remove the marked screw on the side of the camera with a Phillips #000 screwdriver.
  3. Sony Cyber-shot DSC-HX90V LCD Replacement: adım 3, 1 resimden 1.
    • Remove the marked screw with a Phillips #000 screwdriver.
  4. Sony Cyber-shot DSC-HX90V LCD Replacement: adım 4, 2 resimden 1. Sony Cyber-shot DSC-HX90V LCD Replacement: adım 4, 2 resimden 2.
    • Use the plastic opening tool to remove the button board.
  5. Sony Cyber-shot DSC-HX90V LCD Replacement: adım 5, 2 resimden 1. Sony Cyber-shot DSC-HX90V LCD Replacement: adım 5, 2 resimden 2.
    • Disconnect the control board data cable with care. Permanent damage may occur to the control board if tools are used to disconnect the data cable. Use your fingers only.
    • Disconnect the control board data cable by wiggling carefully with your fingertips. Set the control board to the side once it is disconnected.
  6. Sony Cyber-shot DSC-HX90V LCD Replacement, Side cover: adım 6, 1 resimden 1.
    • Use the plastic opening tool with a prying motion to remove the side cover of the camera.
    • The cover should come off easily but you might hear light snapping or popping.
  7. Sony Cyber-shot DSC-HX90V LCD Replacement, LCD: adım 7, 1 resimden 1.
    • Orient the device so the lens is facing down.
    • Remove the two black M1.4 X 3.5 Phillips head screws using Phillips #000 screwdriver.
  8. Sony Cyber-shot DSC-HX90V LCD Replacement: adım 8, 1 resimden 1.
    • Remove the black M1.4 X 3.5 Phillips head screw .
  9. Sony Cyber-shot DSC-HX90V LCD Replacement: adım 9, 2 resimden 1. Sony Cyber-shot DSC-HX90V LCD Replacement: adım 9, 2 resimden 2.
    • LCD screen is very fragile. Handle with care. Do not use tools to remove the screen.
    • Remove the ribbon cable connecting LCD display to camera sensor and battery housing gently.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Marin Rusinov
853 İtibar
5 adet Kılavuz yazıldı
23Kılavuz Yorumları
The title says this is a lens replacement, but isn't it in fact an LCD replacement?
Annika Faelker - Yanıt
This is truly a terrible guide. There are numerous steps missing, steps in the wrong order and little or no description of where and how to apply any pressure to separate or remove parts. I’m glad I didn’t follow this guide as I quite likely would have ruined my camera, or at the very least caused more and quite possibly expensive-to-repair damage. I strongly urge ifixit staff to investigate this guide and remove it, or to at least strongly warn anyone who is contemplating following it.
David - Yanıt
Hallo David,
mit dieser Anleitung habe ich schon mehr als 20 Displays gewechselt und es ist mir noch nie etwas kaputt gegangen. Es fehlt auch nichts was man hätte noch schreiben können. Wenn Du Angst hast etwas kaputt zu machen lass die Finger davon.
Hier rumkritisieren ist schon ein bisschen unverschämt, diese Übersetzung schreibe ich in meiner Freizeit! Du kannst ja eine neue bessere Anleitung schreiben aber vermutlich bist Du jemand der die Finger von solche Reparaturen lassen soll. So eine Reparatur erfordert Sachverstand, wenn es Dir mit dieser Anleitung nicht gelingt, fehlt Dir dieser.
Gruß Detlef
Detlef Dormann -
Entschuldigung,
nach dieser Anleitung habe ich schon 20Displays gewechselt ohne das etwas kaputt gegangen ist.
Wenn man sich dieses nicht zutraut oder 2 linke Daumen hat, Finger weg!
Detlef Dormann - Yanıt
Hello Detlef. Will you consider doing a video tutorial please?
Sarah Bowditch - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 26
Son 30 gün: 134
Her zaman: 9,636
