Ana içeriğe geç
Sony Cyber-shot DSC-P100 Camera Lens Replacement
Katie McCraw
Katie McCraw ve 4 diğer katkıda bulunanlar
En son December 2, 2020 tarihinde güncellendi
15 - 20 dakika
Zor
Yanlış Araçlar
Daha İyi Resimler Gerekli
İşlem Görüntüleri
Daha iyi giriş
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
  1. Sony Cyber-shot DSC-P100 Camera Lens Replacement, Front Casing: adım 1, 3 resimden 1. Sony Cyber-shot DSC-P100 Camera Lens Replacement, Front Casing: adım 1, 3 resimden 2. Sony Cyber-shot DSC-P100 Camera Lens Replacement, Front Casing: adım 1, 3 resimden 3.
    • First locate the appropriate screws for detachment.
    Hi, is this fórum working yet?
    I need tô replace my Sony P100 infernal batery.
    Leonardo - Yanıt
  2. Sony Cyber-shot DSC-P100 Camera Lens Replacement: adım 2, 1 resimden 1.
    • Remove the five screws shown using a Phillips #00 Screwdriver.
    • It is important to put the small screws in a safe location in order to reassemble the casing.
  3. Sony Cyber-shot DSC-P100 Camera Lens Replacement: adım 3, 1 resimden 1.
    • Using a spudger, carefully pry open the front casing.
  4. Sony Cyber-shot DSC-P100 Camera Lens Replacement: adım 4, 2 resimden 1. Sony Cyber-shot DSC-P100 Camera Lens Replacement: adım 4, 2 resimden 2.
    • Carefully separate the front casing from the camera body.
    • CAUTION: Be careful not to break the wire connecting the front casing and the camera.
  5. Sony Cyber-shot DSC-P100 Camera Lens Replacement, Back Casing: adım 5, 3 resimden 1. Sony Cyber-shot DSC-P100 Camera Lens Replacement, Back Casing: adım 5, 3 resimden 2. Sony Cyber-shot DSC-P100 Camera Lens Replacement, Back Casing: adım 5, 3 resimden 3.
    • Remove the four screws from the casing.
  6. Sony Cyber-shot DSC-P100 Camera Lens Replacement: adım 6, 2 resimden 1. Sony Cyber-shot DSC-P100 Camera Lens Replacement: adım 6, 2 resimden 2.
    • Carefully pull the back casing away from the camera.
  7. Sony Cyber-shot DSC-P100 Camera Lens Replacement, Camera Lens: adım 7, 2 resimden 1. Sony Cyber-shot DSC-P100 Camera Lens Replacement, Camera Lens: adım 7, 2 resimden 2.
    • Remove the two screws on the back side of the camera surrounding the LCD screen.
  8. Sony Cyber-shot DSC-P100 Camera Lens Replacement: adım 8, 3 resimden 1. Sony Cyber-shot DSC-P100 Camera Lens Replacement: adım 8, 3 resimden 2. Sony Cyber-shot DSC-P100 Camera Lens Replacement: adım 8, 3 resimden 3.
    • Remove the two ribbon traces found on the left side of the lens on the front of camera holding the lens in place.
    • Carefully pull the lens away front the camera until it is released.
  9. Sony Cyber-shot DSC-P100 Camera Lens Replacement: adım 9, 1 resimden 1.
    • The lens is now successfully removed from the camera.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Katie McCraw
191 İtibar
7 adet Kılavuz yazıldı
Ekip
Clemson, Team 1-5, Benson Spring 2012 Clemson, Team 1-5, Benson Spring 2012 üyesi
CLEM-BENSON-S12S1G5
4 Üyeler
14 adet Kılavuz yazıldı
1Rehber Yorum
Is there a way to disassemble the lens to correct the alignment. My daughter dropped it and I think the mechanism has been misaligned.
Macjune Tolentino - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 30
Her zaman: 2,813
