Ana içeriğe geç
Sony Cyber-shot DSC-T500 Tripod Receptacle Replacement
Chelsea Vitone
Chelsea Vitone ve 3 diğer katkıda bulunanlar
En son May 7, 2024 tarihinde güncellendi
5 - 10 dakika
Kolay
By following 4 easy steps, you will be able to open the camera, locate the tripod receptacle, and replace it.
Neye ihtiyacın var
Aletler
  1. Sony Cyber-shot DSC-T500 Tripod Receptacle Replacement, Front Panel: adım 1, 2 resimden 1. Sony Cyber-shot DSC-T500 Tripod Receptacle Replacement, Front Panel: adım 1, 2 resimden 2.
    • Remove all seven black 4 mm Philips #00 screws holding the front panel into place. Two on each of the sides of the camera and three on the bottom.
  2. Sony Cyber-shot DSC-T500 Tripod Receptacle Replacement: adım 2, 3 resimden 1. Sony Cyber-shot DSC-T500 Tripod Receptacle Replacement: adım 2, 3 resimden 2. Sony Cyber-shot DSC-T500 Tripod Receptacle Replacement: adım 2, 3 resimden 3.
    • Gently lift the front panel up off the back of the camera prying up around the edges using a plastic opening tool or spudger if necessary.
  3. Sony Cyber-shot DSC-T500 Tripod Receptacle Replacement, Remove Inner Screw: adım 3, 2 resimden 1. Sony Cyber-shot DSC-T500 Tripod Receptacle Replacement, Remove Inner Screw: adım 3, 2 resimden 2.
    • Remove the one sliver 4mm Philips #00 screw that is holding the receptacle in place near the bottom of the camera.
    • There is one other screw just like this one on the top of the camera near the capture button. That’s not the one you want to remove here
  4. Sony Cyber-shot DSC-T500 Tripod Receptacle Replacement, Remove Tripod Receptacle: adım 4, 2 resimden 1. Sony Cyber-shot DSC-T500 Tripod Receptacle Replacement, Remove Tripod Receptacle: adım 4, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Remove the tripod receptacle by simply lifting it out with your hands or with tweezers if necessary.
Sonuç
Chelsea Vitone
213 İtibar
2 adet Kılavuz yazıldı
Ekip
UWT Liner: Group 4 UWT Liner: Group 4 üyesi
Community
6 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 6
Son 30 gün: 8
Her zaman: 431
