Ana içeriğe geç
Sony Cyber-shot DSC-W510 Lens Zoom Unit Replacement
Neye ihtiyacın var
  1. Sony Cyber-shot DSC-W510 Lens Zoom Unit Replacement, LCD Screen: adım 1, 1 resimden 1.
    • Place the Sony Cyber-shot DSC-W510 on the magnetic project mat. This will help keep the small screws organized.
  2. Sony Cyber-shot DSC-W510 Lens Zoom Unit Replacement, Unscrew: adım 2, 2 resimden 1. Sony Cyber-shot DSC-W510 Lens Zoom Unit Replacement, Unscrew: adım 2, 2 resimden 2.
    • Using the Phillips #00 screwdriver, unscrew the outside screws from the frame of the camera.
    • There are five screws on the bottom of the camera and two on the side.
    • If the screws are stripped, visit the Removing a Stripped Screw Guide.
  3. Sony Cyber-shot DSC-W510 Lens Zoom Unit Replacement: adım 3, 2 resimden 1. Sony Cyber-shot DSC-W510 Lens Zoom Unit Replacement: adım 3, 2 resimden 2.
    • Pry open the screen frame using a plastic opening tool.
    • It may be necessary to start by prying at one end of the screen and moving around the edge of the screen frame, until it pops out.
  4. Sony Cyber-shot DSC-W510 Lens Zoom Unit Replacement: adım 4, 2 resimden 1. Sony Cyber-shot DSC-W510 Lens Zoom Unit Replacement: adım 4, 2 resimden 2.
    • Using the screw driver, unscrew the one screw on the control panel board.
  5. Sony Cyber-shot DSC-W510 Lens Zoom Unit Replacement: adım 5, 1 resimden 1.
    • Gently unplug the control panel from the motherboard outlet.
  6. Sony Cyber-shot DSC-W510 Lens Zoom Unit Replacement: adım 6, 2 resimden 1. Sony Cyber-shot DSC-W510 Lens Zoom Unit Replacement: adım 6, 2 resimden 2.
    • Using your hands, pry open the LCD screen from the metal board.
    • Gently unplug the LCD screen from the motherboard.
  7. Sony Cyber-shot DSC-W510 Lens Zoom Unit Replacement, Lens Zoom Unit: adım 7, 2 resimden 1. Sony Cyber-shot DSC-W510 Lens Zoom Unit Replacement, Lens Zoom Unit: adım 7, 2 resimden 2.
    • Remove the screws from the metal board using the Phillips #00 screwdriver.
    • Pop apart the metal board using the plastic opening tool.
    • Peel apart the black tape from the flash bulb.
    • Avoid touching the bulb as it will burn or shock if touched.
  8. Sony Cyber-shot DSC-W510 Lens Zoom Unit Replacement: adım 8, 3 resimden 1. Sony Cyber-shot DSC-W510 Lens Zoom Unit Replacement: adım 8, 3 resimden 2. Sony Cyber-shot DSC-W510 Lens Zoom Unit Replacement: adım 8, 3 resimden 3.
    • Pry open the remaining covers of the camera using the plastic opening tool.
    • Some parts may fall out during this process.
  9. Sony Cyber-shot DSC-W510 Lens Zoom Unit Replacement: adım 9, 1 resimden 1.
    • Unscrew the one screw from the motherboard.
    • Disconnect the two links from the camera unit to the motherboard.
  10. Sony Cyber-shot DSC-W510 Lens Zoom Unit Replacement: adım 10, 1 resimden 1.
    • Pop out the lens zoom unit from the frame by using either your thumb or an opening tool.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
kyle
424 İtibar
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 19
Her zaman: 1,524
