Ana içeriğe geç
Sony Cyber-shot DSC-W55 Motherboard - Second Half Replacement
Neye ihtiyacın var
  1. Sony Cyber-shot DSC-W55 Motherboard - Second Half Replacement, Battery: adım 1, 2 resimden 1. Sony Cyber-shot DSC-W55 Motherboard - Second Half Replacement, Battery: adım 1, 2 resimden 2.
    • Slide the battery cover in the direction the arrow points.
    • Pull the battery cover towards you.
    My battery stuck in the camera
    Farida Easmin - Yanıt
    My battery is stuck in the camera
  2. Sony Cyber-shot DSC-W55 Motherboard - Second Half Replacement: adım 2, 2 resimden 1. Sony Cyber-shot DSC-W55 Motherboard - Second Half Replacement: adım 2, 2 resimden 2.
    • Flick the blue switch for the battery to pop out.
    • Remove the battery from the camera.
  3. Sony Cyber-shot DSC-W55 Motherboard - Second Half Replacement, Back Case: adım 3, 2 resimden 1. Sony Cyber-shot DSC-W55 Motherboard - Second Half Replacement, Back Case: adım 3, 2 resimden 2.
    • Using the Phillips #00 screwdriver, remove the two screws from the caution panel.
    • Remove that panel.
    • Careful for falling pieces.
  4. Sony Cyber-shot DSC-W55 Motherboard - Second Half Replacement: adım 4, 2 resimden 1. Sony Cyber-shot DSC-W55 Motherboard - Second Half Replacement: adım 4, 2 resimden 2.
    • Remove the screw with a Phillips #00 screwdriver from the left side of the camera (with '3x optical zoom' engraved on the side panel).
    • Remove the panel.
  5. Sony Cyber-shot DSC-W55 Motherboard - Second Half Replacement: adım 5, 1 resimden 1.
    • Remove the screw using the Phillips #00 screwdriver from the bottom of the camera, closest to the back cover.
  6. Sony Cyber-shot DSC-W55 Motherboard - Second Half Replacement: adım 6, 2 resimden 1. Sony Cyber-shot DSC-W55 Motherboard - Second Half Replacement: adım 6, 2 resimden 2.
    • Gently remove the back cover.
    • It may be a bit stiff, so use some force to remove it. Proceed with caution.
    Muchas gracias, muy claro!!
    Ruben - Yanıt
  7. Sony Cyber-shot DSC-W55 Motherboard - Second Half Replacement, Front Case: adım 7, 1 resimden 1.
    • Remove the screw using a Phillips #00 screwdriver on the right side (where the caution panel used to be).
  8. Sony Cyber-shot DSC-W55 Motherboard - Second Half Replacement: adım 8, 3 resimden 1. Sony Cyber-shot DSC-W55 Motherboard - Second Half Replacement: adım 8, 3 resimden 2. Sony Cyber-shot DSC-W55 Motherboard - Second Half Replacement: adım 8, 3 resimden 3.
    • Remove the small screw using a Phillips #00 screwdriver on the bottom of the camera attached to the front cover.
    • Gently remove the front cover.
    • Put a little force to pop off the case. Proceed with caution.
  9. Sony Cyber-shot DSC-W55 Motherboard - Second Half Replacement, Lens: adım 9, 2 resimden 1. Sony Cyber-shot DSC-W55 Motherboard - Second Half Replacement, Lens: adım 9, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Flip the black secure locks off. Tweezers may be necessary.
    • Detach the two orange cables.
  10. Sony Cyber-shot DSC-W55 Motherboard - Second Half Replacement: adım 10, 2 resimden 1. Sony Cyber-shot DSC-W55 Motherboard - Second Half Replacement: adım 10, 2 resimden 2.
    • Gently pull the lens container out of the camera.
  11. Sony Cyber-shot DSC-W55 Motherboard - Second Half Replacement, Motherboard - First Half: adım 11, 1 resimden 1.
    • Remove the black screw using a Phillips #00 Screwdriver on the motherboard.
  12. Sony Cyber-shot DSC-W55 Motherboard - Second Half Replacement: adım 12, 2 resimden 1. Sony Cyber-shot DSC-W55 Motherboard - Second Half Replacement: adım 12, 2 resimden 2.
    • Remove the two orange cables on the top of the motherboard with tweezers.
    • Lift the motherboard out of its slot.
  13. Sony Cyber-shot DSC-W55 Motherboard - Second Half Replacement: adım 13, 2 resimden 1. Sony Cyber-shot DSC-W55 Motherboard - Second Half Replacement: adım 13, 2 resimden 2.
    • For the AV port, detach the bottom orange cable.
    • For the LCD screen, detach the top orange cable on the right side of the motherboard.
    • For the motherboard, detach all the orange cables.
    • Careful not to damage the red, white, and black wires when lifting the board.
  14. Sony Cyber-shot DSC-W55 Motherboard - Second Half Replacement, LCD Screen: adım 14, 3 resimden 1. Sony Cyber-shot DSC-W55 Motherboard - Second Half Replacement, LCD Screen: adım 14, 3 resimden 2. Sony Cyber-shot DSC-W55 Motherboard - Second Half Replacement, LCD Screen: adım 14, 3 resimden 3.
    • Verify the orange cables from the motherboard are removed from the LCD screen.
    • Lift the LCD screen off the hinge.
  15. Sony Cyber-shot DSC-W55 Motherboard - Second Half Replacement: adım 15, 3 resimden 1. Sony Cyber-shot DSC-W55 Motherboard - Second Half Replacement: adım 15, 3 resimden 2. Sony Cyber-shot DSC-W55 Motherboard - Second Half Replacement: adım 15, 3 resimden 3.
    • Verify that the LCD screen is attached to the chip on the back on the camera.
    • Remove the dial from the back of the camera. It pops right off very easily.
    • Remove the screw using a Phillips #00 Screwdriver from the camera.
  16. Sony Cyber-shot DSC-W55 Motherboard - Second Half Replacement: adım 16, 2 resimden 1. Sony Cyber-shot DSC-W55 Motherboard - Second Half Replacement: adım 16, 2 resimden 2.
    • Remove the orange cable that is attached between the top of the camera and the chip. It should slide straight out with a little bit of force.
    • Remove the chip and the LCD screen now from the camera.
    • The chip may need a slight upward tug with a fingernail or tweezer.
  17. Sony Cyber-shot DSC-W55 Motherboard - Second Half Replacement, Flash Assembly: adım 17, 2 resimden 1. Sony Cyber-shot DSC-W55 Motherboard - Second Half Replacement, Flash Assembly: adım 17, 2 resimden 2.
    • Verify that the orange cables from the top piece are removed from the motherboard.
    • Remove the screw using a Phillips #00 Screwdriver on the upper part of the back side.
    • Pull the top off slowly and with caution. It is still slightly attached and may need a little force.
  18. Sony Cyber-shot DSC-W55 Motherboard - Second Half Replacement: adım 18, 2 resimden 1. Sony Cyber-shot DSC-W55 Motherboard - Second Half Replacement: adım 18, 2 resimden 2.
    • Slowly twist out the flash assembly.
    • It is attached to the hinge so a little force is necessary.
  19. Sony Cyber-shot DSC-W55 Motherboard - Second Half Replacement, Motherboard - Second Half: adım 19, 1 resimden 1.
    • Verify the red, white, and black cables are still attached to the camera.
    • Remove the screw using a Phillips #00 Screwdriver near the AV port
  20. Sony Cyber-shot DSC-W55 Motherboard - Second Half Replacement: adım 20, 3 resimden 1. Sony Cyber-shot DSC-W55 Motherboard - Second Half Replacement: adım 20, 3 resimden 2. Sony Cyber-shot DSC-W55 Motherboard - Second Half Replacement: adım 20, 3 resimden 3.
    • Remove the bottom part of the camera (where the battery is inserted into).
    • This should detach the rest into two pieces. Place the other aside.
  21. Sony Cyber-shot DSC-W55 Motherboard - Second Half Replacement: adım 21, 2 resimden 1. Sony Cyber-shot DSC-W55 Motherboard - Second Half Replacement: adım 21, 2 resimden 2.
    • To remove the crimps, use the spudger to push into gold part of the crimp and pull the wire out gently.
    • Careful not to break the crimps from the wires.
    • Remove the motherboard from the camera.
Sonuç
Andrew Carter
232 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 9-20, Regan Fall 2010 Cal Poly, Team 9-20, Regan Fall 2010 üyesi
CPSU-REGAN-F10S9G20
5 Üyeler
18 adet Kılavuz yazıldı
Bir Yorum
Si I' étais une forme d'objet technique, il me plairait d'être ainsi démonté-remonté.
Mais I ne suis qu'une dite forme de Grand mammifère placentaire respirant en dite basse couche atmosphérique planétaire.
I ne sais ce qu'est l'Intelligence, mais nonobstant que de dite finesse dans ces dites activités anatomiques-physiologiques explicatives.
Merci
Christian
Christian Lecoq - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 11
Her zaman: 5,536
