Ana içeriğe geç
Sony Cyber-shot DSC-W570 Case Cover Replacement
Zizheng Su
Zizheng Su ve 4 diğer katkıda bulunanlar
En son March 7, 2025 tarihinde güncellendi
10 dakika
Kolay
Daha iyi giriş
Öğrenci İş Başında
Outline what you are going to teach someone how to do.
Neye ihtiyacın var
Aletler
  1. Sony Cyber-shot DSC-W570 Case Cover Replacement, Case Cover: adım 1, 1 resimden 1.
    • Begin by facing the camera bottom side up to reveal the two 2.93 mm long screws
    • Remove these two screws using a Philips #00 screwdriver
    • Make sure the battery compartment door is in lock position.
  2. Sony Cyber-shot DSC-W570 Case Cover Replacement: adım 2, 1 resimden 1.
    • Turn the camera sideways on its left side making sure the two 2.93 mm long screws are facing upwards
    • Remove the two 2.93 mm long screws using a Phillips #00 screwdriver
    • Keep all screws on stable surface to not loose them
  3. Sony Cyber-shot DSC-W570 Case Cover Replacement: adım 3, 1 resimden 1.
    • Turn the camera on its right side making sure it is facing upwards
    • Remove the last two 2.93 mm long screws using a Phillips #00 screwdriver
  4. Sony Cyber-shot DSC-W570 Case Cover Replacement: adım 4, 2 resimden 1. Sony Cyber-shot DSC-W570 Case Cover Replacement: adım 4, 2 resimden 2.
    • Face the device with the camera lens facing upwards
    • Now that all the screws are unscrewed, the plastic opening tool will be used to remove the front cover.
    • Gently pry off each corner of the cover to remove it
    • Once all corners are pried off, gently lift off the cover and place it on the side
  5. Sony Cyber-shot DSC-W570 Case Cover Replacement: adım 5, 2 resimden 1. Sony Cyber-shot DSC-W570 Case Cover Replacement: adım 5, 2 resimden 2.
    • Flip the device, making sure the screen is facing upwards
    • The back case should now be visible and ready to remove
    • Use the plastic opening tool to gently pry all along the corners and sides of the camera.
    • Gently lift off the entire back cover and place it on the side
Sonuç
Bir başkası bu kılavuzu tamamladı.
Zizheng Su
101 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 9-1, Brown Winter 2015 USF Tampa, Team 9-1, Brown Winter 2015 üyesi
USFT-BROWN-W15S9G1
5 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 14
Son 30 gün: 25
Her zaman: 834
