Ana içeriğe geç
Sony Cyber-shot DSC-W800 Button Board Replacement
Neye ihtiyacın var
  1. Sony Cyber-shot DSC-W800 Button Board Replacement, Button Board: adım 1, 3 resimden 1. Sony Cyber-shot DSC-W800 Button Board Replacement, Button Board: adım 1, 3 resimden 2. Sony Cyber-shot DSC-W800 Button Board Replacement, Button Board: adım 1, 3 resimden 3.
    • Remove the five 4.0 mm Phillips #000 screws on the back panel.
  2. Sony Cyber-shot DSC-W800 Button Board Replacement: adım 2, 2 resimden 1. Sony Cyber-shot DSC-W800 Button Board Replacement: adım 2, 2 resimden 2.
    • Using the Spudger, remove the back panel from the device.
    • The loose piece circled in the picture will most likely fall off the camera housing.
  3. Sony Cyber-shot DSC-W800 Button Board Replacement: adım 3, 3 resimden 1. Sony Cyber-shot DSC-W800 Button Board Replacement: adım 3, 3 resimden 2. Sony Cyber-shot DSC-W800 Button Board Replacement: adım 3, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Remove the two 2.15mm Phillips #000 screws from the circuit board.
    • Gently pull on the ribbon wire from ZIF connector with the tweezers to remove the button board.
    • Ribbon wires can easily be damaged.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Thomas Campo
827 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 17-5, Blackwell Winter 2016 USF Tampa, Team 17-5, Blackwell Winter 2016 üyesi
USFT-BLACKWELL-W16S17G5
5 Üyeler
5 adet Kılavuz yazıldı
4Kılavuz Yorumları
Thanks for this - was spot on and allowed me to easily fix the problem I was experiencing!
jimbradshaw - Yanıt
follow the step camera button loosen a bit unstuck but camera still stock on language setting and do not budge
Trisha Amable Girlfridayz - Yanıt
follow the step the button are unstuck but the camera display still stock on language setting
i need a new strip, because old strip was damaged.
moonbhaai@gmail.com
Naveed Shoukat - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 14
Son 30 gün: 74
Her zaman: 2,877
