Ana içeriğe geç
Sony Cyber-shot DSC-WX100 Battery Replacement
Peter Prins
Peter Prins ve 2 diğer katkıda bulunanlar
En son June 22, 2015 tarihinde güncellendi
5 dakika
Çok kolay
The purpose of this guide is to provide instruction on replacing an exhausted or damaged battery.
  1. Sony Cyber-shot DSC-WX100 Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Open the flap indicated to allow access to the battery slot.
    • The gray switch indicated has to be moved to the right in order to release the flap.
  2. Sony Cyber-shot DSC-WX100 Battery Replacement: adım 2, 1 resimden 1.
    • If the old battery is still in the slot, then make sure the camera is turned off prior to removal.
    • If there is a battery currently in the slot, remove by first pulling downwards on the blue component. This will allow you to remove the battery from the slot.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Peter Prins
262 İtibar
2 adet Kılavuz yazıldı
Ekip
Michigan Tech, Team 1-9, Lauer Spring 2015 Michigan Tech, Team 1-9, Lauer Spring 2015 üyesi
MTU-LAUER-S15S1G9
2 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 3
Son 30 gün: 6
Her zaman: 1,102
