Ana içeriğe geç
Sony Cyber-shot DSC-WX100 Outer Casing Replacement
Neye ihtiyacın var
  1. Sony Cyber-shot DSC-WX100 Outer Casing Replacement, Battery: adım 1, 1 resimden 1.
    • Open the flap indicated to allow access to the battery slot.
    • The gray switch indicated has to be moved to the right in order to release the flap.
  2. Sony Cyber-shot DSC-WX100 Outer Casing Replacement: adım 2, 1 resimden 1.
    • If the old battery is still in the slot, then make sure the camera is turned off prior to removal.
    • If there is a battery currently in the slot, remove by first pulling downwards on the blue component. This will allow you to remove the battery from the slot.
    Be careful, i got an electrical shock even after removing the battery when i touched the inner case. i guess, you have to wait some time for static electricity to disapear
    Timm von der Mehden - Yanıt
  3. Sony Cyber-shot DSC-WX100 Outer Casing Replacement, Outer Casing: adım 3, 3 resimden 1. Sony Cyber-shot DSC-WX100 Outer Casing Replacement, Outer Casing: adım 3, 3 resimden 2. Sony Cyber-shot DSC-WX100 Outer Casing Replacement, Outer Casing: adım 3, 3 resimden 3.
    • Remove all of the 1mm screws using a Philips #000 Screwdriver.
    • Remover the rest of the screws (2mm) from the camera covers using a Phillips #000 Screwdriver.
  4. Sony Cyber-shot DSC-WX100 Outer Casing Replacement: adım 4, 2 resimden 1. Sony Cyber-shot DSC-WX100 Outer Casing Replacement: adım 4, 2 resimden 2.
    • Use the plastic opening tool to gently remove the front and back plates of the camera.
  5. Sony Cyber-shot DSC-WX100 Outer Casing Replacement: adım 5, 2 resimden 1. Sony Cyber-shot DSC-WX100 Outer Casing Replacement: adım 5, 2 resimden 2.
    • Use a plastic opening tool to gently release the two indicated tabs.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Matthew
583 İtibar
4 adet Kılavuz yazıldı
Ekip
Michigan Tech, Team 1-9, Lauer Spring 2015 Michigan Tech, Team 1-9, Lauer Spring 2015 üyesi
MTU-LAUER-S15S1G9
2 Üyeler
6 adet Kılavuz yazıldı
Bir Yorum
Where I can buy the Outer Casing..¿??
ING CHARLY - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 8
Her zaman: 943
