Ana içeriğe geç
Sony Cybershot DSC-W80 Lens Replacement
Kierra Taylor
Kierra Taylor ve başka bir katkıda bulunan
En son February 7, 2021 tarihinde güncellendi
10 dakika
Orta
This guide will show how to replace the camera lens on a Sony Cyber-Shot DSC-W80.
Neye ihtiyacın var
Aletler
  1. Sony Cybershot DSC-W80 Lens Replacement, Battery: adım 1, 2 resimden 1. Sony Cybershot DSC-W80 Lens Replacement, Battery: adım 1, 2 resimden 2.
    • Open the battery cover by sliding it towards you.
  2. Sony Cybershot DSC-W80 Lens Replacement: adım 2, 1 resimden 1.
    • Push the purple latch with your thumb to unlock the battery.
    • Pull the battery out.
  3. Sony Cybershot DSC-W80 Lens Replacement, Front/Back Panels: adım 3, 3 resimden 1. Sony Cybershot DSC-W80 Lens Replacement, Front/Back Panels: adım 3, 3 resimden 2. Sony Cybershot DSC-W80 Lens Replacement, Front/Back Panels: adım 3, 3 resimden 3.
    • Remove the eight Phillips #000 screws.
  4. Sony Cybershot DSC-W80 Lens Replacement: adım 4, 1 resimden 1.
    • Remove the single Phillips #000 screw found next to the battery latch.
  5. Sony Cybershot DSC-W80 Lens Replacement: adım 5, 2 resimden 1. Sony Cybershot DSC-W80 Lens Replacement: adım 5, 2 resimden 2.
    • Remove the middle panel on the side of the device.
    • Slowly pry the camera apart at its seem.
  6. Sony Cybershot DSC-W80 Lens Replacement, Lens: adım 6, 3 resimden 1. Sony Cybershot DSC-W80 Lens Replacement, Lens: adım 6, 3 resimden 2. Sony Cybershot DSC-W80 Lens Replacement, Lens: adım 6, 3 resimden 3.
    • Disconnect all ribbon cables by using the flat end of a spudger to lift up the black tabs on the ZIF connectors.
    • Once disconnected, use your fingers to lift lens out of the frame.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 22
Son 30 gün: 44
Her zaman: 892
