Ana içeriğe geç
Sony DSC-RX100MA SD Card Holder Replacement
Isaiah De Leon
Isaiah De Leon ve 4 diğer katkıda bulunanlar
En son May 7, 2024 tarihinde güncellendi
30 dakika
Orta
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
  1. Sony DSC-RX100MA SD Card Holder Replacement, Back Cover: adım 1, 3 resimden 1. Sony DSC-RX100MA SD Card Holder Replacement, Back Cover: adım 1, 3 resimden 2. Sony DSC-RX100MA SD Card Holder Replacement, Back Cover: adım 1, 3 resimden 3.
    • Remove battery by sliding the tab to open the cover
  2. Sony DSC-RX100MA SD Card Holder Replacement: adım 2, 3 resimden 1. Sony DSC-RX100MA SD Card Holder Replacement: adım 2, 3 resimden 2. Sony DSC-RX100MA SD Card Holder Replacement: adım 2, 3 resimden 3.
    • Using the screwdriver, remove all screws (black 2.5mm) from outermost layer of the assembly.
    • All screws in the camera can be removed with the PH 0 driver head.
    Split this step up into multiple steps based on where screws are being removed from or specify how many screws are removed in this step
    Alberto Rodriguez - Yanıt
  3. Sony DSC-RX100MA SD Card Holder Replacement: adım 3, 3 resimden 1. Sony DSC-RX100MA SD Card Holder Replacement: adım 3, 3 resimden 2. Sony DSC-RX100MA SD Card Holder Replacement: adım 3, 3 resimden 3.
    • Also using the screwdriver, remove screws (black 1mm) underneath articulated LCD screen.
    • Remove the marked 2.5 mm screws with the screwdriver
    2 different types of screws are removed in this step: specify the types
    It is not necessary to remove the hinge screws. It is much easier to remove the back panel with the LCD still attached and not flopping about everywhere.
    cheez - Yanıt
  4. Sony DSC-RX100MA SD Card Holder Replacement: adım 4, 2 resimden 1. Sony DSC-RX100MA SD Card Holder Replacement: adım 4, 2 resimden 2.
    • Using the plastic opening tools, carefully pry off the bottom plate.
    • Do not pull too hard as you may break the plastic casing.
  5. Sony DSC-RX100MA SD Card Holder Replacement: adım 5, 3 resimden 1. Sony DSC-RX100MA SD Card Holder Replacement: adım 5, 3 resimden 2. Sony DSC-RX100MA SD Card Holder Replacement: adım 5, 3 resimden 3.
    • Using the same plastic opening tools, separate the screen and back assembly from the front portion of the camera
    • Once the back assembly is slightly detached, pull the media covers for the HDMI and Multimedia ports
  6. Sony DSC-RX100MA SD Card Holder Replacement: adım 6, 2 resimden 1. Sony DSC-RX100MA SD Card Holder Replacement: adım 6, 2 resimden 2.
    • Remove the back cover
  7. Sony DSC-RX100MA SD Card Holder Replacement, Screen: adım 7, 3 resimden 1. Sony DSC-RX100MA SD Card Holder Replacement, Screen: adım 7, 3 resimden 2. Sony DSC-RX100MA SD Card Holder Replacement, Screen: adım 7, 3 resimden 3.
    • Move side panel to get access to screws
    • Remove two screws (black 2.5mm) with PH #0 screwdriver
    In the second picture of the side, it is not the upper screw by the USB that needs removing, but the lower one by the SD/battery door
    James Robinson - Yanıt
  8. Sony DSC-RX100MA SD Card Holder Replacement: adım 8, 2 resimden 1. Sony DSC-RX100MA SD Card Holder Replacement: adım 8, 2 resimden 2.
    • Remove back panel assembly while still keeping ribbon cable attached
    • Be very gentle and care not to tear the gold ribbon cable. This will be a common theme throughout these replacement guides.
  9. Sony DSC-RX100MA SD Card Holder Replacement: adım 9, 2 resimden 1. Sony DSC-RX100MA SD Card Holder Replacement: adım 9, 2 resimden 2.
    • Carefully unplug ribbon connector to fully detach LCD screen assembly from camera
    It is worth saying that the grey line on the left-hand edge of the flex connector flips up to release the flex.
    And Rew - Yanıt
  10. Sony DSC-RX100MA SD Card Holder Replacement, SD Card Holder: adım 10, 2 resimden 1. Sony DSC-RX100MA SD Card Holder Replacement, SD Card Holder: adım 10, 2 resimden 2.
    • Remove remaining screw which holds the copper casing in the camera
    this is the HDMI cover
  11. Sony DSC-RX100MA SD Card Holder Replacement: adım 11, 3 resimden 1. Sony DSC-RX100MA SD Card Holder Replacement: adım 11, 3 resimden 2. Sony DSC-RX100MA SD Card Holder Replacement: adım 11, 3 resimden 3.
    • Using the plastic opening tools, carefully pry off the copper casing at the two pictured points.
    • Remove casing
    I still have two black glued maybe cables above the copper board. Can't find them in the description but they are already missing in your picture of step 10.
    Simon - Yanıt
    The connector next to the display connector is unplugged in the last picture of step 11 but not mentioned in the text.
    Simon - Yanıt
  12. Sony DSC-RX100MA SD Card Holder Replacement: adım 12, 3 resimden 1. Sony DSC-RX100MA SD Card Holder Replacement: adım 12, 3 resimden 2. Sony DSC-RX100MA SD Card Holder Replacement: adım 12, 3 resimden 3.
    • Using Philips Screwdriver, remove the four screws as marked on the picture
  13. Sony DSC-RX100MA SD Card Holder Replacement: adım 13, 3 resimden 1. Sony DSC-RX100MA SD Card Holder Replacement: adım 13, 3 resimden 2. Sony DSC-RX100MA SD Card Holder Replacement: adım 13, 3 resimden 3.
    • Place your finger into the battery port and push up on the SD card holder to push it out of its socket.
    • Give it a little wiggle and you should feel the SD card holder come out.
    Warning Take care because at this stage the senor chip will become exposed to contamination. the grey plate is its heatsink.
    Mal Beckford - Yanıt
    The small cover of the HDMI port was removed here as well.
    Simon - Yanıt
  14. Sony DSC-RX100MA SD Card Holder Replacement: adım 14, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Carefully remove the gold ribbons from the ports of the motherboard by lifting the gray tabs and pulling away the ribbon
    • You may want to use tweezers to remove the gold ribbons as a more delicate and safe approach, but this is not required
    • Do not pull away motherboard too hard as the ribbons are very fragile
  15. Sony DSC-RX100MA SD Card Holder Replacement: adım 15, 1 resimden 1.
    • Remove the SD card holder. It should easily come out because all of the prerequisite screws were already removed.
Sonuç
Isaiah De Leon
439 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 21-1, Maness Winter 2017 Cal Poly, Team 21-1, Maness Winter 2017 üyesi
CPSU-MANESS-W17S21G1
5 Üyeler
10 adet Kılavuz yazıldı
Bir Yorum
Dear Isaiah De Leon !
I have a Sony RX 100 Mk4, and it is out of order.  :(
First just the digital zoom button (up on the camera) didn't work
Later the manual zoom (lens ring moving) didn't work
Now the rest of the marked buttons does not work.
(Sometimes yes, but usually no funcion at all)
The camera was handled care, didn't fall down, no water contact!
Sony service says, no physical problem, they advise the panel to be replaced. (It is about 120€ + 60€ working fee)
Some Sony fan member advised “the little cable just under dial there that connects all the controls has slowly slipped out. “ could be the problem,
Could You please send a picture which cable can it be, or please any other advice.
Thanks!!!
Ádám
berkesi.adam@gmail.com
adama1492 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 17
Son 30 gün: 27
Her zaman: 1,438
