Ana içeriğe geç
Sony DualSense Controller Button Replacement
Neye ihtiyacın var
  1. Sony DualSense Controller Button Replacement, Unclip the right end of the middle trim: adım 1, 2 resimden 1. Sony DualSense Controller Button Replacement, Unclip the right end of the middle trim: adım 1, 2 resimden 2.
    • Disconnect and power down your controller before you begin.
    • Insert an opening pick underneath the middle trim at the bottom-right corner of the controller to release the clips securing it to the case.
  2. Sony DualSense Controller Button Replacement, Unclip the lower-right edge of the middle trim: adım 2, 3 resimden 1. Sony DualSense Controller Button Replacement, Unclip the lower-right edge of the middle trim: adım 2, 3 resimden 2. Sony DualSense Controller Button Replacement, Unclip the lower-right edge of the middle trim: adım 2, 3 resimden 3.
    • Slide the opening pick along the lower-right edge of the middle trim to release the clips securing it to the case.
  3. Sony DualSense Controller Button Replacement, Unclip the left end of the middle trim: adım 3, 2 resimden 1. Sony DualSense Controller Button Replacement, Unclip the left end of the middle trim: adım 3, 2 resimden 2.
    • Insert an opening pick underneath the middle trim at the bottom-left corner of the controller to release the clips securing it to the case.
  4. Sony DualSense Controller Button Replacement, Unclip the lower-left edge of the middle trim: adım 4, 3 resimden 1. Sony DualSense Controller Button Replacement, Unclip the lower-left edge of the middle trim: adım 4, 3 resimden 2. Sony DualSense Controller Button Replacement, Unclip the lower-left edge of the middle trim: adım 4, 3 resimden 3.
    • Slide the opening pick along the lower-left edge of the middle trim to release the clips securing it to the case.
  5. Sony DualSense Controller Button Replacement, Remove the middle trim: adım 5, 3 resimden 1. Sony DualSense Controller Button Replacement, Remove the middle trim: adım 5, 3 resimden 2. Sony DualSense Controller Button Replacement, Remove the middle trim: adım 5, 3 resimden 3.
    • Use your fingers to lift up the bottom edge of the middle trim to release the remaining clips.
    • Lift the middle trim over the joysticks to remove it.
  6. Sony DualSense Controller Button Replacement, Remove the L1 button: adım 6, 3 resimden 1. Sony DualSense Controller Button Replacement, Remove the L1 button: adım 6, 3 resimden 2. Sony DualSense Controller Button Replacement, Remove the L1 button: adım 6, 3 resimden 3.
    • Insert the flat end of a spudger into the gap above the L1 button.
    • Cover the button with your thumb to prevent it from ejecting across the room.
    • Pry upward to remove the L1 button.
  7. Sony DualSense Controller Button Replacement, Remove the R1 button: adım 7, 3 resimden 1. Sony DualSense Controller Button Replacement, Remove the R1 button: adım 7, 3 resimden 2. Sony DualSense Controller Button Replacement, Remove the R1 button: adım 7, 3 resimden 3.
    • Insert the flat end of a spudger into the gap above the R1 button.
    • Pry upward to remove the R1 button.
  8. Sony DualSense Controller Button Replacement, Remove the rear case: adım 8, 2 resimden 1. Sony DualSense Controller Button Replacement, Remove the rear case: adım 8, 2 resimden 2.
    • Use a Phillips screwdriver to remove the two 6.4 mm screws securing the bottom corners of the lower case.
  9. Sony DualSense Controller Button Replacement: adım 9, 2 resimden 1. Sony DualSense Controller Button Replacement: adım 9, 2 resimden 2.
    • Use a Phillips screwdriver to remove the two 6.4 mm screws behind the L1 and R1 buttons.
  10. Sony DualSense Controller Button Replacement: adım 10, 3 resimden 1. Sony DualSense Controller Button Replacement: adım 10, 3 resimden 2. Sony DualSense Controller Button Replacement: adım 10, 3 resimden 3.
    • Use the pointed edge of a spudger to unclip the two clips on either side of the headset jack.
  11. Sony DualSense Controller Button Replacement: adım 11, 2 resimden 1. Sony DualSense Controller Button Replacement: adım 11, 2 resimden 2.
    • Remove the rear case.
    • On some revisions, the rear case is held with two more clips next to the previously removed bumpers. If the rear case doesn't open without force, check for those clips.
  12. Sony DualSense Controller Button Replacement, Disconnect the battery: adım 12, 2 resimden 1. Sony DualSense Controller Button Replacement, Disconnect the battery: adım 12, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Use a pair of tweezers or your fingers to disconnect the battery from the motherboard.
    • Grip the connector, not the wires, when disconnecting.
  13. Sony DualSense Controller Button Replacement, Remove the battery: adım 13, 2 resimden 1. Sony DualSense Controller Button Replacement, Remove the battery: adım 13, 2 resimden 2.
    • Lift the battery straight out of the battery bracket.
  14. Sony DualSense Controller Button Replacement, Remove the lower microphone: adım 14, 2 resimden 1. Sony DualSense Controller Button Replacement, Remove the lower microphone: adım 14, 2 resimden 2.
    Satın Al
    • Grab the lower microphone ribbon cable pull tab with your fingers or a pair of tweezers and disconnect it from the motherboard.
  15. Sony DualSense Controller Button Replacement, Remove the battery bracket: adım 15, 2 resimden 1. Sony DualSense Controller Button Replacement, Remove the battery bracket: adım 15, 2 resimden 2.
    • Use a Phillips screwdriver to remove the 6.4 mm screw securing the battery bracket.
  16. Sony DualSense Controller Button Replacement: adım 16, 2 resimden 1. Sony DualSense Controller Button Replacement: adım 16, 2 resimden 2.
    • Lift the battery bracket out of the motherboard.
  17. Sony DualSense Controller Button Replacement, Disconnect the right trigger assembly: adım 17, 2 resimden 1. Sony DualSense Controller Button Replacement, Disconnect the right trigger assembly: adım 17, 2 resimden 2.
    • Grip the right trigger assembly ribbon cable pull tab with a pair of tweezers or your fingers and pull up to disconnect it from the motherboard.
    • Do not completely remove the ribbon cable yet.
  18. Sony DualSense Controller Button Replacement: adım 18, 2 resimden 1. Sony DualSense Controller Button Replacement: adım 18, 2 resimden 2.
    • Grip the right trigger assembly ribbon cable pull tab with a pair of tweezers or your fingers, and pull up to disconnect it from the trigger assembly.
    • Remove the ribbon cable.
  19. Sony DualSense Controller Button Replacement, Disconnect the left trigger assembly: adım 19, 2 resimden 1. Sony DualSense Controller Button Replacement, Disconnect the left trigger assembly: adım 19, 2 resimden 2.
    • Grip the left trigger assembly ribbon cable pull tab with a pair of tweezers or your fingers and pull up to disconnect it from the motherboard.
  20. Sony DualSense Controller Button Replacement: adım 20, 2 resimden 1. Sony DualSense Controller Button Replacement: adım 20, 2 resimden 2.
    • Grip the left trigger assembly ribbon cable pull tab with a pair of tweezers or your fingers, and pull up to disconnect it from the trigger assembly.
  21. Sony DualSense Controller Button Replacement, Disconnect the upper microphone: adım 21, 2 resimden 1. Sony DualSense Controller Button Replacement, Disconnect the upper microphone: adım 21, 2 resimden 2.
    • Use a pair of tweezers or your fingers to grip the upper microphone ribbon cable pull tab, and pull up to disconnect it from the motherboard.
  22. Sony DualSense Controller Button Replacement, Disconnect the touchpad: adım 22, 2 resimden 1. Sony DualSense Controller Button Replacement, Disconnect the touchpad: adım 22, 2 resimden 2.
    • Use a pair of tweezers or your fingers to grip the touchpad ribbon cable pull tab, and pull it straight out of the motherboard connector.
  23. Sony DualSense Controller Button Replacement, Lift out the motherboard: adım 23, 3 resimden 1. Sony DualSense Controller Button Replacement, Lift out the motherboard: adım 23, 3 resimden 2. Sony DualSense Controller Button Replacement, Lift out the motherboard: adım 23, 3 resimden 3.
    • Carefully guide the joysticks through the front case and lift the motherboard out.
    • Do not completely remove the motherboard. There are four soldered wires tethering the motherboard to the vibrator motors.
  24. Sony DualSense Controller Button Replacement, Remove the light guide: adım 24, 2 resimden 1. Sony DualSense Controller Button Replacement, Remove the light guide: adım 24, 2 resimden 2.
    • Use a Phillips screwdriver to remove the two 8.5 mm screws securing the light guide.
  25. Sony DualSense Controller Button Replacement: adım 25, 2 resimden 1. Sony DualSense Controller Button Replacement: adım 25, 2 resimden 2.
    Satın Al
    • Use a pair of tweezers or your fingers to remove the light guide bracket.
  26. Sony DualSense Controller Button Replacement: adım 26, 2 resimden 1. Sony DualSense Controller Button Replacement: adım 26, 2 resimden 2.
    • Use a pair of tweezers or your fingers to remove the light guide.
  27. Sony DualSense Controller Button Replacement, Remove the speaker: adım 27, 3 resimden 1. Sony DualSense Controller Button Replacement, Remove the speaker: adım 27, 3 resimden 2. Sony DualSense Controller Button Replacement, Remove the speaker: adım 27, 3 resimden 3.
    Satın Al
    • Use a pair of tweezers to remove the speaker from the midframe.
    • Be sure to reinstall the speaker in the correct orientation with the foam pad on the left side and the gold contact points on the right.
  28. Sony DualSense Controller Button Replacement, Remove the midframe: adım 28, 2 resimden 1. Sony DualSense Controller Button Replacement, Remove the midframe: adım 28, 2 resimden 2.
    • Use a Phillips screwdriver to remove the two 6.4 mm screws securing the midframe to the front case.
  29. Sony DualSense Controller Button Replacement: adım 29, 3 resimden 1. Sony DualSense Controller Button Replacement: adım 29, 3 resimden 2. Sony DualSense Controller Button Replacement: adım 29, 3 resimden 3.
    • Carefully lift the midframe and motherboard up and out of the front case.
    • Be careful not to strain the vibrator motor wires.
    • During reassembly, feed the touchpad's ribbon cable back through its rectangular opening in the midframe.
  30. Sony DualSense Controller Button Replacement, Remove the conductive silicone rubber: adım 30, 3 resimden 1. Sony DualSense Controller Button Replacement, Remove the conductive silicone rubber: adım 30, 3 resimden 2. Sony DualSense Controller Button Replacement, Remove the conductive silicone rubber: adım 30, 3 resimden 3.
    Satın Al
    • Use a pair of tweezers or your fingers to remove the three conductive silicone rubber pads from the inside of the front case.
    • The buttons are resting loose in the front case.
  31. Sony DualSense Controller Button Replacement, Remove the buttons: adım 31, 1 resimden 1.
    • Hold the front case close to the surface of your table and slowly turn the front case over to let the buttons fall out.
Sonuç
25 farklı kişi bu kılavuzu tamamladı.
Sam Omiotek
76.055 İtibar
288 adet Kılavuz yazıldı
3 Yorum
good step by step list. easy to follow. thanks
Marc Lazure - Yanıt
Wayyyyy too much Daddy-O
Guy - Yanıt
Thanks for the awesome guide. I fixed my sticky buttons.
Jan - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 107
Son 7 gün: 788
Son 30 gün: 3,697
Her zaman: 56,394
