Giriş
Follow this guide to replace the joystick covers on a Sony PlayStation 5 DualSense controller.
Note: This guide is for DualSense controllers with an FCC ID ending in 1. Check the back of your controller to verify your model. If yours ends in A, there will be differences in the internal design, but you can still use this guide.
Neye ihtiyacın var
Insert an opening pick underneath the middle trim at the bottom-right corner of the controller to release the clips securing it to the case.
Slide the opening pick along the lower-right edge of the middle trim to release the clips securing it to the case.
Insert an opening pick underneath the middle trim at the bottom-left corner of the controller to release the clips securing it to the case.
Slide the opening pick along the lower-left edge of the middle trim to release the clips securing it to the case.
Use your fingers to lift up the bottom edge of the middle trim to release the remaining clips.
Lift the middle trim over the joysticks to remove it.
With one hand, grip the controller and use your thumb to hold down the left trigger.
With your free hand, insert the flat end of a spudger between the L1 and L2 buttons.
Use the spudger to gently pry the L1 button away from the controller and remove it, holding your finger over the button so it doesn't eject.
Use a Phillips screwdriver to remove the two 6.4 mm screws securing the bottom corners of the lower case.
Use the point of a spudger to release the two clips on either side of the headset jack.
Bu adımda kullanılan alet:Tweezers$4.99
Use a pair of tweezers or your fingers to disconnect the battery from the motherboard.
Grab the lower microphone ribbon cable pull tab with your fingers or a pair of tweezers and disconnect it from the motherboard.
Use a Phillips screwdriver to remove the 6.4 mm screw securing the battery bracket.
Grip the right trigger assembly ribbon cable pull tab with a pair of tweezers or your fingers and pull up to disconnect it from the motherboard.
Grip the left trigger assembly ribbon cable pull tab with a pair of tweezers or your fingers and pull up to disconnect it from the motherboard.
Use a pair of tweezers or your fingers to grip the upper microphone ribbon cable pull tab, and pull up to disconnect it from the motherboard.
Use a pair of tweezers or your fingers to grip the touchpad ribbon cable pull tab, and pull it straight out of the motherboard connector.
Carefully guide the joysticks through the front case and lift the motherboard out.
The motherboard is held down by two clips. One between the motherboard itself and the right trigger assembly, and one between the motherboard itself and the left trigger assembly. Gently push on either clip to release the motherboard from its restraints.
Use your fingers to pull the joystick covers straight up and off of their modules.
112 farklı kişi bu kılavuzu tamamladı.
13Kılavuz Yorumları
Sony did ever came up with a modular design on their PSP-1000 (Joystick Replacement) which does not require soldering only contact pins such like Xbox Series X headphone output
This was really good i manage to fix my controller on my own for the first time. Thanks!
A great guide, just a few small comments:
1. When removing the R1/L1 buttons - do it gently, otherwise they could fly off around the room. Lucky for me my R1 hit the bookshelf behind me and then landed right next to my hand, but usually that's not the case.
2. DO NOT turn the device upside down while the motherboard is disconnected. There's a small rectangular piece that's not connected to anything and might move around and prevent reassembly or worse - you could lose it and not even know about it. I have no idea what that piece is but I'm sure I want it in my controller.
3. When putting back the motherboard be sure to place the microphone first and make sure the flat cable is accessible to you once the mother board is in place.
I replaced my right analog stick to fix stick drift but it got worse, my characters on the game wont stop spinning. I can’t even aim anywhere else it’s like the right stick is stuck moving left, can anyone help?
