Ana içeriğe geç
Sony DualSense Controller L1 and R1 Button Replacement
Neye ihtiyacın var
  1. Sony DualSense Controller L1 and R1 Button Replacement, Remove the L1 button: adım 1, 3 resimden 1. Sony DualSense Controller L1 and R1 Button Replacement, Remove the L1 button: adım 1, 3 resimden 2. Sony DualSense Controller L1 and R1 Button Replacement, Remove the L1 button: adım 1, 3 resimden 3.
    • With one hand, grip the controller and use your thumb to hold down the left trigger.
    • With your free hand, insert the flat end of a spudger between the L1 and L2 buttons.
    • Use the spudger to gently pry the L1 button away from the controller and remove it, holding your finger over the button so it doesn't eject.
  2. Sony DualSense Controller L1 and R1 Button Replacement, Remove the R1 button: adım 2, 3 resimden 1. Sony DualSense Controller L1 and R1 Button Replacement, Remove the R1 button: adım 2, 3 resimden 2. Sony DualSense Controller L1 and R1 Button Replacement, Remove the R1 button: adım 2, 3 resimden 3.
    • Repeat the previous step to remove the R1 button.
Sonuç
9 farklı kişi bu kılavuzu tamamladı.
Sam Omiotek
85.170 İtibar
290 adet Kılavuz yazıldı
3Kılavuz Yorumları
It is easier to remove L1/R1 by going from below than by from above- without any damages.
Grim Of Doom - Yanıt
Does the spudger dent or mark the button when doing this?
Rory Bedell - Yanıt
My replacement R1 button is different enough to not fit. Fins around center sleeve are wider. So there must have been a design change at some point.
Walt Mather - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 48
Son 7 gün: 267
Son 30 gün: 1,797
Her zaman: 33,028
