Ana içeriğe geç
Sony DualSense Controller Rear Case Replacement
Neye ihtiyacın var
  1. Sony DualSense Controller Rear Case Replacement, Unclip the right end of the middle trim: adım 1, 2 resimden 1. Sony DualSense Controller Rear Case Replacement, Unclip the right end of the middle trim: adım 1, 2 resimden 2.
    • Disconnect and power down your controller before you begin.
    • Insert an opening pick underneath the middle trim at the bottom-right corner of the controller to release the clips securing it to the case.
  2. Sony DualSense Controller Rear Case Replacement, Unclip the lower-right edge of the middle trim: adım 2, 3 resimden 1. Sony DualSense Controller Rear Case Replacement, Unclip the lower-right edge of the middle trim: adım 2, 3 resimden 2. Sony DualSense Controller Rear Case Replacement, Unclip the lower-right edge of the middle trim: adım 2, 3 resimden 3.
    • Slide the opening pick along the lower-right edge of the middle trim to release the clips securing it to the case.
  3. Sony DualSense Controller Rear Case Replacement, Unclip the left end of the middle trim: adım 3, 2 resimden 1. Sony DualSense Controller Rear Case Replacement, Unclip the left end of the middle trim: adım 3, 2 resimden 2.
    • Insert an opening pick underneath the middle trim at the bottom-left corner of the controller to release the clips securing it to the case.
  4. Sony DualSense Controller Rear Case Replacement, Unclip the lower-left edge of the middle trim: adım 4, 3 resimden 1. Sony DualSense Controller Rear Case Replacement, Unclip the lower-left edge of the middle trim: adım 4, 3 resimden 2. Sony DualSense Controller Rear Case Replacement, Unclip the lower-left edge of the middle trim: adım 4, 3 resimden 3.
    • Slide the opening pick along the lower-left edge of the middle trim to release the clips securing it to the case.
  5. Sony DualSense Controller Rear Case Replacement, Remove the middle trim: adım 5, 3 resimden 1. Sony DualSense Controller Rear Case Replacement, Remove the middle trim: adım 5, 3 resimden 2. Sony DualSense Controller Rear Case Replacement, Remove the middle trim: adım 5, 3 resimden 3.
    • Use your fingers to lift up the bottom edge of the middle trim to release the remaining clips.
    • Lift the middle trim over the joysticks to remove it.
  6. Sony DualSense Controller Rear Case Replacement, Remove the L1 button: adım 6, 3 resimden 1. Sony DualSense Controller Rear Case Replacement, Remove the L1 button: adım 6, 3 resimden 2. Sony DualSense Controller Rear Case Replacement, Remove the L1 button: adım 6, 3 resimden 3.
    • With one hand, grip the controller and use your thumb to hold down the left trigger.
    • With your free hand, insert the flat end of a spudger between the L1 and L2 buttons.
    • Use the spudger to gently pry the L1 button away from the controller and remove it, holding your finger over the button so it doesn't eject.
  7. Sony DualSense Controller Rear Case Replacement, Remove the R1 button: adım 7, 3 resimden 1. Sony DualSense Controller Rear Case Replacement, Remove the R1 button: adım 7, 3 resimden 2. Sony DualSense Controller Rear Case Replacement, Remove the R1 button: adım 7, 3 resimden 3.
    • Repeat the previous step to remove the R1 button.
  8. Sony DualSense Controller Rear Case Replacement, Remove the rear case screws: adım 8, 2 resimden 1. Sony DualSense Controller Rear Case Replacement, Remove the rear case screws: adım 8, 2 resimden 2.
    • Use a Phillips screwdriver to remove the two 6.4 mm screws securing the bottom corners of the lower case.
  9. Sony DualSense Controller Rear Case Replacement: adım 9, 2 resimden 1. Sony DualSense Controller Rear Case Replacement: adım 9, 2 resimden 2.
    • Use a Phillips screwdriver to remove the two 6.4 mm screws behind the L1 and R1 buttons.
  10. Sony DualSense Controller Rear Case Replacement, Separate the rear case: adım 10, 3 resimden 1. Sony DualSense Controller Rear Case Replacement, Separate the rear case: adım 10, 3 resimden 2. Sony DualSense Controller Rear Case Replacement, Separate the rear case: adım 10, 3 resimden 3.
    • Be gentle when releasing the rear cover clips—they're delicate and can easily break.
    • Use the point of a spudger to release the two clips on either side of the headset jack.
  11. Sony DualSense Controller Rear Case Replacement: adım 11, 3 resimden 1. Sony DualSense Controller Rear Case Replacement: adım 11, 3 resimden 2. Sony DualSense Controller Rear Case Replacement: adım 11, 3 resimden 3.
    • Tight plastic clips secure the left and right edges of the rear case.
    • Insert the flat end of a spudger between the front and rear shells near the bottom of the left edge.
    • Slide the spudger along the left edge and gently pry the shells apart to release the clips.
  12. Sony DualSense Controller Rear Case Replacement: adım 12, 3 resimden 1. Sony DualSense Controller Rear Case Replacement: adım 12, 3 resimden 2. Sony DualSense Controller Rear Case Replacement: adım 12, 3 resimden 3.
    • Repeat the previous step on the right edge to release its clips.
  13. Sony DualSense Controller Rear Case Replacement: adım 13, 2 resimden 1. Sony DualSense Controller Rear Case Replacement: adım 13, 2 resimden 2.
    • Lay your controller upside down so the joysticks are on your work surface.
    • Hold the controller down with your fingers and use your thumbs to lift the rear case away from the controller to fully separate it.
  14. Sony DualSense Controller Rear Case Replacement, Remove the rear case: adım 14, 1 resimden 1.
    • Remove the rear case.
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Sam Omiotek
85.194 İtibar
290 adet Kılavuz yazıldı
1Rehber Yorum
Where do i get fitting rear cases?
Zoonk Dng - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 27
Son 7 gün: 139
Son 30 gün: 1,061
Her zaman: 19,397
