Ana içeriğe geç
Sony DualSense Controller Touchpad Replacement
Neye ihtiyacın var
  1. Sony DualSense Controller Touchpad Replacement, Unclip the right end of the middle trim: adım 1, 2 resimden 1. Sony DualSense Controller Touchpad Replacement, Unclip the right end of the middle trim: adım 1, 2 resimden 2.
    • Disconnect and power down your controller before you begin.
    • Insert an opening pick underneath the middle trim at the bottom-right corner of the controller to release the clips securing it to the case.
    FixBot'a Sor
    Yorum Ekle
  2. Sony DualSense Controller Touchpad Replacement, Unclip the lower-right edge of the middle trim: adım 2, 3 resimden 1. Sony DualSense Controller Touchpad Replacement, Unclip the lower-right edge of the middle trim: adım 2, 3 resimden 2. Sony DualSense Controller Touchpad Replacement, Unclip the lower-right edge of the middle trim: adım 2, 3 resimden 3.
    • Slide the opening pick along the lower-right edge of the middle trim to release the clips securing it to the case.
    FixBot'a Sor
    Yorum Ekle
  3. Sony DualSense Controller Touchpad Replacement, Unclip the left end of the middle trim: adım 3, 2 resimden 1. Sony DualSense Controller Touchpad Replacement, Unclip the left end of the middle trim: adım 3, 2 resimden 2.
    • Insert an opening pick underneath the middle trim at the bottom-left corner of the controller to release the clips securing it to the case.
    FixBot'a Sor
    Yorum Ekle
  4. Sony DualSense Controller Touchpad Replacement, Unclip the lower-left edge of the middle trim: adım 4, 3 resimden 1. Sony DualSense Controller Touchpad Replacement, Unclip the lower-left edge of the middle trim: adım 4, 3 resimden 2. Sony DualSense Controller Touchpad Replacement, Unclip the lower-left edge of the middle trim: adım 4, 3 resimden 3.
    • Slide the opening pick along the lower-left edge of the middle trim to release the clips securing it to the case.
    FixBot'a Sor
    Yorum Ekle
  5. Sony DualSense Controller Touchpad Replacement, Remove the middle trim: adım 5, 3 resimden 1. Sony DualSense Controller Touchpad Replacement, Remove the middle trim: adım 5, 3 resimden 2. Sony DualSense Controller Touchpad Replacement, Remove the middle trim: adım 5, 3 resimden 3.
    • Use your fingers to lift up the bottom edge of the middle trim to release the remaining clips.
    • Lift the middle trim over the joysticks to remove it.
    FixBot'a Sor
    Yorum Ekle
  6. Sony DualSense Controller Touchpad Replacement, Remove the L1 button: adım 6, 3 resimden 1. Sony DualSense Controller Touchpad Replacement, Remove the L1 button: adım 6, 3 resimden 2. Sony DualSense Controller Touchpad Replacement, Remove the L1 button: adım 6, 3 resimden 3.
    • With one hand, grip the controller and use your thumb to hold down the left trigger.
    • With your free hand, insert the flat end of a spudger between the L1 and L2 buttons.
    • Use the spudger to gently pry the L1 button away from the controller and remove it, holding your finger over the button so it doesn't eject.
    FixBot'a Sor
    Yorum Ekle
  7. Sony DualSense Controller Touchpad Replacement, Remove the R1 button: adım 7, 3 resimden 1. Sony DualSense Controller Touchpad Replacement, Remove the R1 button: adım 7, 3 resimden 2. Sony DualSense Controller Touchpad Replacement, Remove the R1 button: adım 7, 3 resimden 3.
    • Repeat the previous step to remove the R1 button.
    FixBot'a Sor
    Yorum Ekle
  8. Sony DualSense Controller Touchpad Replacement, Remove the rear case screws: adım 8, 2 resimden 1. Sony DualSense Controller Touchpad Replacement, Remove the rear case screws: adım 8, 2 resimden 2.
    • Use a Phillips screwdriver to remove the two 6.4 mm screws securing the bottom corners of the lower case.
    FixBot'a Sor
    Yorum Ekle
  9. Sony DualSense Controller Touchpad Replacement: adım 9, 2 resimden 1. Sony DualSense Controller Touchpad Replacement: adım 9, 2 resimden 2.
    • Use a Phillips screwdriver to remove the two 6.4 mm screws behind the L1 and R1 buttons.
    FixBot'a Sor
    Yorum Ekle
  10. Sony DualSense Controller Touchpad Replacement, Separate the rear case: adım 10, 3 resimden 1. Sony DualSense Controller Touchpad Replacement, Separate the rear case: adım 10, 3 resimden 2. Sony DualSense Controller Touchpad Replacement, Separate the rear case: adım 10, 3 resimden 3.
    • Be gentle when releasing the rear cover clips—they're delicate and can easily break.
    • Use the point of a spudger to release the two clips on either side of the headset jack.
    FixBot'a Sor
    Yorum Ekle
  11. Sony DualSense Controller Touchpad Replacement: adım 11, 3 resimden 1. Sony DualSense Controller Touchpad Replacement: adım 11, 3 resimden 2. Sony DualSense Controller Touchpad Replacement: adım 11, 3 resimden 3.
    • Tight plastic clips secure the left and right edges of the rear case.
    • Insert the flat end of a spudger between the front and rear shells near the bottom of the left edge.
    • Slide the spudger along the left edge and gently pry the shells apart to release the clips.
    FixBot'a Sor
    Yorum Ekle
  12. Sony DualSense Controller Touchpad Replacement: adım 12, 3 resimden 1. Sony DualSense Controller Touchpad Replacement: adım 12, 3 resimden 2. Sony DualSense Controller Touchpad Replacement: adım 12, 3 resimden 3.
    • Repeat the previous step on the right edge to release its clips.
    FixBot'a Sor
    Yorum Ekle
  13. Sony DualSense Controller Touchpad Replacement: adım 13, 2 resimden 1. Sony DualSense Controller Touchpad Replacement: adım 13, 2 resimden 2.
    • Lay your controller upside down so the joysticks are on your work surface.
    • Hold the controller down with your fingers and use your thumbs to lift the rear case away from the controller to fully separate it.
    FixBot'a Sor
    Yorum Ekle
  14. Sony DualSense Controller Touchpad Replacement, Remove the rear case: adım 14, 1 resimden 1.
    • Remove the rear case.
    FixBot'a Sor
    Yorum Ekle
  15. Sony DualSense Controller Touchpad Replacement, Disconnect the battery: adım 15, 2 resimden 1. Sony DualSense Controller Touchpad Replacement, Disconnect the battery: adım 15, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Use a pair of tweezers or your fingers to disconnect the battery from the motherboard.
    • Grip the connector, not the wires, when disconnecting.
    FixBot'a Sor
    Yorum Ekle
  16. Sony DualSense Controller Touchpad Replacement, Remove the battery: adım 16, 2 resimden 1. Sony DualSense Controller Touchpad Replacement, Remove the battery: adım 16, 2 resimden 2.
    • Lift the battery straight out of the battery bracket.
    FixBot'a Sor
    Yorum Ekle
  17. Sony DualSense Controller Touchpad Replacement, Remove the lower microphone: adım 17, 2 resimden 1. Sony DualSense Controller Touchpad Replacement, Remove the lower microphone: adım 17, 2 resimden 2.
    • Grab the lower microphone ribbon cable pull tab with your fingers or a pair of tweezers and disconnect it from the motherboard.
    FixBot'a Sor
    Yorum Ekle
  18. Sony DualSense Controller Touchpad Replacement, Remove the battery bracket: adım 18, 2 resimden 1. Sony DualSense Controller Touchpad Replacement, Remove the battery bracket: adım 18, 2 resimden 2.
    • Use a Phillips screwdriver to remove the 6.4 mm screw securing the battery bracket.
    FixBot'a Sor
    Yorum Ekle
  19. Sony DualSense Controller Touchpad Replacement: adım 19, 2 resimden 1. Sony DualSense Controller Touchpad Replacement: adım 19, 2 resimden 2.
    • Lift the battery bracket out of the motherboard.
    FixBot'a Sor
    Yorum Ekle
  20. Sony DualSense Controller Touchpad Replacement, Disconnect the right trigger assembly: adım 20, 2 resimden 1. Sony DualSense Controller Touchpad Replacement, Disconnect the right trigger assembly: adım 20, 2 resimden 2.
    • Grip the right trigger assembly ribbon cable pull tab with a pair of tweezers or your fingers and pull up to disconnect it from the motherboard.
    • Do not completely remove the ribbon cable yet.
    FixBot'a Sor
    Yorum Ekle
  21. Sony DualSense Controller Touchpad Replacement: adım 21, 2 resimden 1. Sony DualSense Controller Touchpad Replacement: adım 21, 2 resimden 2.
    • Grip the right trigger assembly ribbon cable pull tab with a pair of tweezers or your fingers, and pull up to disconnect it from the trigger assembly.
    • Remove the ribbon cable.
    FixBot'a Sor
    Yorum Ekle
  22. Sony DualSense Controller Touchpad Replacement, Disconnect the left trigger assembly: adım 22, 2 resimden 1. Sony DualSense Controller Touchpad Replacement, Disconnect the left trigger assembly: adım 22, 2 resimden 2.
    • Grip the left trigger assembly ribbon cable pull tab with a pair of tweezers or your fingers and pull up to disconnect it from the motherboard.
    FixBot'a Sor
    Yorum Ekle
  23. Sony DualSense Controller Touchpad Replacement: adım 23, 2 resimden 1. Sony DualSense Controller Touchpad Replacement: adım 23, 2 resimden 2.
    • Grip the left trigger assembly ribbon cable pull tab with a pair of tweezers or your fingers, and pull up to disconnect it from the trigger assembly.
    FixBot'a Sor
    Yorum Ekle
  24. Sony DualSense Controller Touchpad Replacement, Disconnect the upper microphone: adım 24, 2 resimden 1. Sony DualSense Controller Touchpad Replacement, Disconnect the upper microphone: adım 24, 2 resimden 2.
    • Use a pair of tweezers or your fingers to grip the upper microphone ribbon cable pull tab, and pull up to disconnect it from the motherboard.
    FixBot'a Sor
    Yorum Ekle
  25. Sony DualSense Controller Touchpad Replacement, Disconnect the touchpad: adım 25, 2 resimden 1. Sony DualSense Controller Touchpad Replacement, Disconnect the touchpad: adım 25, 2 resimden 2.
    • Use a pair of tweezers or your fingers to grip the touchpad ribbon cable pull tab, and pull it straight out of the motherboard connector.
    FixBot'a Sor
    Yorum Ekle
  26. Sony DualSense Controller Touchpad Replacement, Lift out the motherboard: adım 26, 3 resimden 1. Sony DualSense Controller Touchpad Replacement, Lift out the motherboard: adım 26, 3 resimden 2. Sony DualSense Controller Touchpad Replacement, Lift out the motherboard: adım 26, 3 resimden 3.
    • Carefully guide the joysticks through the front case and lift the motherboard out.
    • The motherboard is held down by two clips. One between the motherboard itself and the right trigger assembly, and one between the motherboard itself and the left trigger assembly. Gently push on either clip to release the motherboard from its restraints.
    • Do not completely remove the motherboard. There are four soldered wires tethering the motherboard to the vibrator motors.
    FixBot'a Sor
    Yorum Ekle
  27. Sony DualSense Controller Touchpad Replacement, Remove the light guide: adım 27, 2 resimden 1. Sony DualSense Controller Touchpad Replacement, Remove the light guide: adım 27, 2 resimden 2.
    • Use a Phillips screwdriver to remove the two 8.5 mm screws securing the light guide.
    FixBot'a Sor
    Yorum Ekle
  28. Sony DualSense Controller Touchpad Replacement: adım 28, 2 resimden 1. Sony DualSense Controller Touchpad Replacement: adım 28, 2 resimden 2.
    • Use a pair of tweezers or your fingers to remove the light guide bracket.
    FixBot'a Sor
    Yorum Ekle
  29. Sony DualSense Controller Touchpad Replacement: adım 29, 2 resimden 1. Sony DualSense Controller Touchpad Replacement: adım 29, 2 resimden 2.
    • Use a pair of tweezers or your fingers to remove the light guide.
    FixBot'a Sor
    Yorum Ekle
  30. Sony DualSense Controller Touchpad Replacement, Remove the speaker: adım 30, 3 resimden 1. Sony DualSense Controller Touchpad Replacement, Remove the speaker: adım 30, 3 resimden 2. Sony DualSense Controller Touchpad Replacement, Remove the speaker: adım 30, 3 resimden 3.
    • Use a pair of tweezers to remove the speaker from the midframe.
    • Be sure to reinstall the speaker in the correct orientation with the foam pad on the left side and the gold contact points on the right.
    FixBot'a Sor
    Yorum Ekle
  31. Sony DualSense Controller Touchpad Replacement, Remove the midframe: adım 31, 2 resimden 1. Sony DualSense Controller Touchpad Replacement, Remove the midframe: adım 31, 2 resimden 2.
    • Use a Phillips screwdriver to remove the two 6.4 mm screws securing the midframe to the front case.
    FixBot'a Sor
    Yorum Ekle
  32. Sony DualSense Controller Touchpad Replacement: adım 32, 3 resimden 1. Sony DualSense Controller Touchpad Replacement: adım 32, 3 resimden 2. Sony DualSense Controller Touchpad Replacement: adım 32, 3 resimden 3.
    • Carefully lift the midframe and motherboard up and out of the front case.
    • Be careful not to strain the vibrator motor wires.
    • During reassembly, feed the touchpad's ribbon cable back through its rectangular opening in the midframe.
    FixBot'a Sor
    Yorum Ekle
  33. Sony DualSense Controller Touchpad Replacement, Remove the touchpad: adım 33, 2 resimden 1. Sony DualSense Controller Touchpad Replacement, Remove the touchpad: adım 33, 2 resimden 2.
    • Use a Phillips screwdriver to remove the two 6.4 mm screws securing the touchpad bracket to the touchpad.
    FixBot'a Sor
    Yorum Ekle
  34. Sony DualSense Controller Touchpad Replacement: adım 34, 3 resimden 1. Sony DualSense Controller Touchpad Replacement: adım 34, 3 resimden 2. Sony DualSense Controller Touchpad Replacement: adım 34, 3 resimden 3.
    • Lift the touchpad bracket straight up off the front case.
    • Feed the ribbon cable back through the rectangular slot in the bracket during reassembly.
    FixBot'a Sor
    Yorum Ekle
  35. Sony DualSense Controller Touchpad Replacement: adım 35, 1 resimden 1.
    • Lift the front case up off of the touchpad.
    FixBot'a Sor
    Yorum Ekle
Sonuç
12 farklı kişi bu kılavuzu tamamladı.
Sam Omiotek
99.442 İtibar
290 adet Kılavuz yazıldı
12Kılavuz Yorumları
New touch won’t work with motherboard
Manson Knowz - Yanıt Paylaş
Can you elaborate? I’m looking to buy one of these for this repair, and not sure which, or where
Gregg Cerenzio - Yanıt Paylaş
Hii, first of all big fan but i am havinf trouble finding the touchpad motherboard online to replace mine like i am talking about the whole unit cus the ribbon that is atach to mine i glued on and cant replase the ribbon so if you guys can help me find it would be a big help thx
patrick yard - Yanıt Paylaş
Did you found a replacement part? I'm looking for the same thing
Julian Giraldo - Yanıt Paylaş
if I'm understanding correctly, you can use a hair dryer to heat up the touchpad and melt the adhesive that holds it to the board. Then do the reverse to the new touch pad.
Hope this helps!
LoudmouthdSHNK - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 26
Son 7 gün: 185
Son 30 gün: 2,416
Her zaman: 65,628
