Ana içeriğe geç
Sony H.ear On 2 Motherboard Replacement
Neye ihtiyacın var
  1. Sony H.ear On 2 Motherboard Replacement, Motherboard: adım 1, 2 resimden 1. Sony H.ear On 2 Motherboard Replacement, Motherboard: adım 1, 2 resimden 2.
    • Start on the left side by using the plastic opening tool in the crease between the ear cup and plastic. Gently apply pressure until it separates.
    • Do not force any parts off as the plastic holders may snap off if too much pressure is applied.
  2. Sony H.ear On 2 Motherboard Replacement: adım 2, 2 resimden 1. Sony H.ear On 2 Motherboard Replacement: adım 2, 2 resimden 2.
    • Use the JIS #00 Screwdriver to remove the 2 6.4mm screws holding in the motherboard.
  3. Sony H.ear On 2 Motherboard Replacement: adım 3, 3 resimden 1. Sony H.ear On 2 Motherboard Replacement: adım 3, 3 resimden 2. Sony H.ear On 2 Motherboard Replacement: adım 3, 3 resimden 3.
    • De-solder all 18 wire-connections on the motherboard.
    • Record wire positions on board for proper connections when re-soldering the replacement board.
    • Do not overheat joints while de-soldering to prevent board damage.
    • Please see How To Solder and Desolder Connections for help on soldering and desoldering connections.
  4. Sony H.ear On 2 Motherboard Replacement: adım 4, 2 resimden 1. Sony H.ear On 2 Motherboard Replacement: adım 4, 2 resimden 2.
    • Disconnect the white ribbon cable by gently tugging on the white connector while holding the motherboard carefully in place.
  5. Sony H.ear On 2 Motherboard Replacement: adım 5, 1 resimden 1.
    • Gently remove the old motherboard from the bracket assembly and replace and resolder motherboard.
Sonuç
Michael Long
131 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team S9-G11, Maness Spring 2019 Cal Poly, Team S9-G11, Maness Spring 2019 üyesi
CPSU-MANESS-S19S9G11
5 Üyeler
16 adet Kılavuz yazıldı
Bir Yorum
where can i find a replacement motherboard for these headphones?
MTL - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 11
Son 30 gün: 22
Her zaman: 1,529
