Ana içeriğe geç
Sony ICF-P26 Antenna Replacement
Olaloye Thontteh
Olaloye Thontteh ve başka bir katkıda bulunan
En son September 3, 2020 tarihinde güncellendi
15 dakika
Kolay
Use this guide to fix or replace a damaged antenna of a Sony ICF-P26 radio.
The antenna enables radios to get reception for their FM and AM bandwidth. A radio with no antenna or a damaged antenna would have distortion of radio waves .
Following these steps would fix the radio reception issues in a short time. There is minimal or no known danger associated with replacing the antenna .
Neye ihtiyacın var
Aletler
  1. Sony ICF-P26 Antenna Replacement, Antenna: adım 1, 2 resimden 1. Sony ICF-P26 Antenna Replacement, Antenna: adım 1, 2 resimden 2.
    • Power off and disconnect the radio from any power source.
  2. Sony ICF-P26 Antenna Replacement: adım 2, 3 resimden 1. Sony ICF-P26 Antenna Replacement: adım 2, 3 resimden 2. Sony ICF-P26 Antenna Replacement: adım 2, 3 resimden 3.
    • Use a mini screwdriver to remove the two screws from the battery compartment.
    • Gently insert an opening tool where the FM/AM/Off switch is, to force your way up.
    • Insert the opening tool in the other side where the volume and the earphone go.
    • You will hear hinges pop open.
  3. Sony ICF-P26 Antenna Replacement: adım 3, 3 resimden 1. Sony ICF-P26 Antenna Replacement: adım 3, 3 resimden 2. Sony ICF-P26 Antenna Replacement: adım 3, 3 resimden 3.
    • Use the mini screwdriver to remove the screw holding the motherboard.
    • Unscrew the damaged antenna.
  4. Sony ICF-P26 Antenna Replacement: adım 4, 3 resimden 1. Sony ICF-P26 Antenna Replacement: adım 4, 3 resimden 2. Sony ICF-P26 Antenna Replacement: adım 4, 3 resimden 3.
    • Use the mini screwdriver to replace the new antenna.
  5. Sony ICF-P26 Antenna Replacement: adım 5, 2 resimden 1. Sony ICF-P26 Antenna Replacement: adım 5, 2 resimden 2.
    • Use the mini screwdriver to assemble the motherboard.
  6. Sony ICF-P26 Antenna Replacement: adım 6, 3 resimden 1. Sony ICF-P26 Antenna Replacement: adım 6, 3 resimden 2. Sony ICF-P26 Antenna Replacement: adım 6, 3 resimden 3.
    • Use the mini screwdriver to assemble the cover.
    • Insert the batteries.
  7. Sony ICF-P26 Antenna Replacement: adım 7, 2 resimden 1. Sony ICF-P26 Antenna Replacement: adım 7, 2 resimden 2.
    • Switch on the radio.
    Thanks for this!
    J Gibson - Yanıt
    A good guide my dude but anyone who has zero experience could struggle a bit because the steps are not 100%clear
    Ivan Monterrubio - Yanıt
Bitiş Çizgisi
4 farklı kişi bu kılavuzu tamamladı.
2Kılavuz Yorumları
Where would one acquire a compatible replacement antenna for this model of radio?
Mason Smith - Yanıt
Thank you so much. The difficulty is opening the case. You explained it very well. My problem was the dirty potentiometer. I simply poured enough isopropyl alcool on it, to "wash" it, it flowed inside, turn it few times, that was all. Works as new. Thank you.
Jean-Yves Béguec - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 14
Son 30 gün: 56
Her zaman: 4,196
