Ana içeriğe geç
Sony MDR-XB450AP Extra Bass Headphones Speaker Replacement
Neye ihtiyacın var
  1. Sony MDR-XB450AP Extra Bass Headphones Speaker Replacement, Swivel: adım 1, 1 resimden 1.
    • Begin by laying the headphones down flat with the speakers facing up.
    • Be sure to unplug the headphones from any other devices.
  2. Sony MDR-XB450AP Extra Bass Headphones Speaker Replacement: adım 2, 2 resimden 1. Sony MDR-XB450AP Extra Bass Headphones Speaker Replacement: adım 2, 2 resimden 2.
    • Next, take out the screws that hold the front plate, using a J00 screwdriver.
    • Repeat for both the left and right screws.
    • These screws are very small. It is helpful to have a spot prepared to put the screws to avoid losing pieces.
  3. Sony MDR-XB450AP Extra Bass Headphones Speaker Replacement: adım 3, 1 resimden 1.
    • Now that the screws have been removed, pull away the plastic casing that covers the swivel piece (directly above the speaker).
  4. Sony MDR-XB450AP Extra Bass Headphones Speaker Replacement: adım 4, 1 resimden 1.
    • Now that the swivel piece is exposed, use a J00 screwdriver to unscrew the center screw.
    • Repeat this process on both sides if necessary.
    • This center screw is the piece that retains the swivel action, unscrew completely and remove to replace.
  5. Sony MDR-XB450AP Extra Bass Headphones Speaker Replacement, Cushion: adım 5, 1 resimden 1.
    • Begin by laying the headphones down flat on a surface.
    • Make sure that the headphone speakers are facing upward.
    • Be sure to check that the headphones are not plugged into any devices.
  6. Sony MDR-XB450AP Extra Bass Headphones Speaker Replacement: adım 6, 1 resimden 1.
    • Using the plastic opening tools, gently pry the speaker from the headphone's base.
    • There will be some tearing involved, but this is necessary to remove the original cushion.
    • The cushion is bonded to the headphones with a circular adhesive strip. If you plan on reusing the cushion, try to keep the adhesive attached to the cushion during removal. This way the cushion can be easily re-attached to the headphones after repair.
  7. Sony MDR-XB450AP Extra Bass Headphones Speaker Replacement, Speaker: adım 7, 1 resimden 1.
    • Remove the speaker from the headband to proceed.
  8. Sony MDR-XB450AP Extra Bass Headphones Speaker Replacement: adım 8, 1 resimden 1.
    • Use a J0 screw driver to unscrew the four screws located underneath on the cushion.
    • The four screws are positioned around the perimeter of the speaker's surface
  9. Sony MDR-XB450AP Extra Bass Headphones Speaker Replacement: adım 9, 1 resimden 1.
    • Pry open the front case using the J0 screwdriver.
  10. Sony MDR-XB450AP Extra Bass Headphones Speaker Replacement: adım 10, 1 resimden 1.
    • Simply pull away the speaker component to expose the under part of the speaker.
    • The wire will still be attached to the bottom of the speaker
  11. Sony MDR-XB450AP Extra Bass Headphones Speaker Replacement: adım 11, 2 resimden 1. Sony MDR-XB450AP Extra Bass Headphones Speaker Replacement: adım 11, 2 resimden 2.
    • With the under part of the speaker exposed, remove the broken speaker from the wires and solder on the new speaker
    • Indicated on the image to the left shows the two points the speaker can be soldered
    • Use cation when performing soldering. Soldering can be dangerous if not performed correctly with care. See the iFixit guide page on soldering here.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
4 Yorum
Hey Thanks for The speaker replacement information of Sony MDR-XB450AP Extra Bass Headphones and if you want to buy new headphone/earphoneplaease take a look at :
https://bestigeek.com/best-earphones-und...
Thanks
Regards
Nilesh - Yanıt
I really love this headphones, i have this headphone but in good condition not that type. but if you want to check new pair of headphones or earphones then here is the list
https://gadgetorg.com/best-headphones-un...
Regards
prashant - Yanıt
I have the same headphones and the left ear cup cables are completely detached that side also has the inline controls and mic so there are four wires i dont know what to do with the inline control wires
abdullahwasif - Yanıt
Where we get to buy sony headphones spaeker
ANAND KRISHNAN - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 32
Her zaman: 9,365
