Ana içeriğe geç
Sony SRS-XB43 LED Module Replacement
Neye ihtiyacın var
    1. Sony SRS-XB43 LED Module Replacement, Faceplate: adım 1, 2 resimden 1. Sony SRS-XB43 LED Module Replacement, Faceplate: adım 1, 2 resimden 2.
      • Insert the metal spudger into the mesh's seam/opening located at the bottom of the speaker.
      • Begin applying pressure, prying along the run of the seam until the mesh cover begins to come loose.
      • Fully open the hinged mesh cover and pry it off the unit.
      FixBot'a Sor
      Yorum Ekle
    2. Sony SRS-XB43 LED Module Replacement: adım 2, 1 resimden 1.
      • Turn the speaker so the back is facing you.
      • Remove the factory tamper seal below the speaker volume toggle to reveal a single screw.
      • Remove the single screw using a T8 Torx.
      FixBot'a Sor
      Yorum Ekle
    3. Sony SRS-XB43 LED Module Replacement: adım 3, 1 resimden 1.
      • Remove all ten screws using a Phillips #1 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    4. Sony SRS-XB43 LED Module Replacement: adım 4, 2 resimden 1. Sony SRS-XB43 LED Module Replacement: adım 4, 2 resimden 2.
      • Slowly lift the speaker face off of the housing unit.
      • Unplug the six wires connecting the faceplate to the motherboard.
      FixBot'a Sor
      Yorum Ekle
    1. Sony SRS-XB43 LED Module Replacement, Battery: adım 5, 2 resimden 1. Sony SRS-XB43 LED Module Replacement, Battery: adım 5, 2 resimden 2.
      • Orient the speaker's backplate so that the plastic chassis and internal electronics are facing upwards.
      • Remove the eight 10 mm screws securing the motherboard chassis to the backplate using a Phillips #1 screwdriver.
      • Grab the motherboard chassis and gently remove it from the backplate of the speaker.
      FixBot'a Sor
      Yorum Ekle
    2. Sony SRS-XB43 LED Module Replacement: adım 6, 3 resimden 1. Sony SRS-XB43 LED Module Replacement: adım 6, 3 resimden 2. Sony SRS-XB43 LED Module Replacement: adım 6, 3 resimden 3.
      • Orient the motherboard chassis so that the side with the six buttons is facedown on the table and the opposite side is visible to you.
      • Disconnect the seven-prong cable (the one with red, yellow, and black wires) plugged into the motherboard by prying on its edge/extruding lip with a spudger.
      FixBot'a Sor
      Yorum Ekle
    3. Sony SRS-XB43 LED Module Replacement: adım 7, 2 resimden 1. Sony SRS-XB43 LED Module Replacement: adım 7, 2 resimden 2.
      • Orient the plastic chassis so that the port housing PCB is facing upward.
      • Remove the plastic black film covering the battery, leaving the blue battery exposed.
      FixBot'a Sor
      Yorum Ekle
    4. Sony SRS-XB43 LED Module Replacement: adım 8, 2 resimden 1. Sony SRS-XB43 LED Module Replacement: adım 8, 2 resimden 2.
      • Lightly pull the seven-prong cable upwards until the battery is angled in such a way that you can get a proper grip on both sides with your fingers.
      • Using your fingers, pull upwards until the battery is removed from its enclosure.
      • Do not use a spudger or other flat tools to pry in between the seam of the battery and the battery compartment, as it is possible to damage the battery.
      FixBot'a Sor
      Yorum Ekle
    1. Sony SRS-XB43 LED Module Replacement, LED Module: adım 9, 1 resimden 1.
      • Orient the motherboard chassis so that the battery compartment is facing upwards.
      • Identify the two LED control PCBs located on the left and right edges of the plastic chassis.
      FixBot'a Sor
      Yorum Ekle
    2. Sony SRS-XB43 LED Module Replacement: adım 10, 3 resimden 1. Sony SRS-XB43 LED Module Replacement: adım 10, 3 resimden 2. Sony SRS-XB43 LED Module Replacement: adım 10, 3 resimden 3.
      • Identify the black latch on each of the plugs that are connected to the PBCs.
      • Swing the black latch open by gently prying the front/extruding lip of the plug with a spudger or other flat tool.
      • To give a sense of direction, the latch should swing away from you or towards the LED (metallic square).
      • Grab each ribbon cable and apply a horizontal pulling force (with respect to the LED control PCBs) to disconnect them from the connectors.
      FixBot'a Sor
      Yorum Ekle
    3. Sony SRS-XB43 LED Module Replacement: adım 11, 3 resimden 1. Sony SRS-XB43 LED Module Replacement: adım 11, 3 resimden 2. Sony SRS-XB43 LED Module Replacement: adım 11, 3 resimden 3.
      Bu adımda kullanılan alet:
      Plastic Cards
      $2.99
      • Insert the spudger below the LED control PCBs and pry to remove it from the plastic chassis.
      • The PCBs are held onto the chassis with a considerably strong double-sided tape. If the spudger is too thick and can not fit under the PCBs, use a thin plastic pick or plastic card.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Isaac Oliveira
282 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 3-5, Botvin Fall 2022 UMass Dartmouth, Team 3-5, Botvin Fall 2022 üyesi
UMASSD-BOTVIN-F22S3G5
4 Üyeler
10 adet Kılavuz yazıldı
1Rehber Yorum
i need email to contact You please
Danny Bryan Vega - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 10
Son 30 gün: 40
Her zaman: 976
