Ana içeriğe geç
Sony SRS-XB43 Speaker Replacement
Neye ihtiyacın var
  1. Sony SRS-XB43 Speaker Replacement, Faceplate: adım 1, 2 resimden 1. Sony SRS-XB43 Speaker Replacement, Faceplate: adım 1, 2 resimden 2.
    • Insert the metal spudger into the mesh's seam/opening located at the bottom of the speaker.
    • Begin applying pressure, prying along the run of the seam until the mesh cover begins to come loose.
    • Fully open the hinged mesh cover and pry it off the unit.
  2. Sony SRS-XB43 Speaker Replacement: adım 2, 1 resimden 1.
    • Turn the speaker so the back is facing you.
    • Remove the factory tamper seal below the speaker volume toggle to reveal a single screw.
    • Remove the single screw using a T8 Torx.
  3. Sony SRS-XB43 Speaker Replacement: adım 3, 1 resimden 1.
    • Remove all ten screws using a Phillips #1 screwdriver.
  4. Sony SRS-XB43 Speaker Replacement: adım 4, 2 resimden 1. Sony SRS-XB43 Speaker Replacement: adım 4, 2 resimden 2.
    • Slowly lift the speaker face off of the housing unit.
    • Unplug the six wires connecting the faceplate to the motherboard.
  5. Sony SRS-XB43 Speaker Replacement, Speaker: adım 5, 3 resimden 1. Sony SRS-XB43 Speaker Replacement, Speaker: adım 5, 3 resimden 2. Sony SRS-XB43 Speaker Replacement, Speaker: adım 5, 3 resimden 3.
    • On the face plate of the speaker, locate the black ribbon cable plugged into the green circuit board to your right.
    • Grab the ribbon cable from its base and apply a light verticle force upwards to unplug it from the PCB.
    • This step prevents the cable from getting in the way of the right speaker as it is being removed.
  6. Sony SRS-XB43 Speaker Replacement: adım 6, 1 resimden 1.
    • Remove eight black 10 mm screws attached to the speaker plate using a Phillips #1 screwdriver.
  7. Sony SRS-XB43 Speaker Replacement: adım 7, 2 resimden 1. Sony SRS-XB43 Speaker Replacement: adım 7, 2 resimden 2.
    • Remove the two individual speakers.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Bishoy Mikhail
253 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 3-5, Botvin Fall 2022 UMass Dartmouth, Team 3-5, Botvin Fall 2022 üyesi
UMASSD-BOTVIN-F22S3G5
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 15
Son 30 gün: 53
Her zaman: 991
