Ana içeriğe geç
Sony Vaio Fit 13A Heatsink + Fan Assembly Replacement
Neye ihtiyacın var
  1. Sony Vaio Fit 13A Heatsink + Fan Assembly Replacement, Back Cover: adım 1, 2 resimden 1. Sony Vaio Fit 13A Heatsink + Fan Assembly Replacement, Back Cover: adım 1, 2 resimden 2.
    • Starting with the laptop top-down, locate and remove the twelve 1mm Phillips #0 screws securing the back cover to the main body of the computer.
  2. Sony Vaio Fit 13A Heatsink + Fan Assembly Replacement: adım 2, 2 resimden 1. Sony Vaio Fit 13A Heatsink + Fan Assembly Replacement: adım 2, 2 resimden 2.
    • Use the Plastic Opening Tools or Metal Spudger to carefully loosen back cover from the body of the computer.
    • Be sure to avoid headphone jack when removing back cover by lifting cover away from computer and up.
  3. Sony Vaio Fit 13A Heatsink + Fan Assembly Replacement: adım 3, 1 resimden 1.
    • Lift off back cover to access inner components of computer.
  4. Sony Vaio Fit 13A Heatsink + Fan Assembly Replacement, Fan: adım 4, 2 resimden 1. Sony Vaio Fit 13A Heatsink + Fan Assembly Replacement, Fan: adım 4, 2 resimden 2.
    • Remove the three 1mm Phillips #0 screws surrounding the fan.
    • Loosen the three 1mm Phillips #0 screws. These screws will stay captive to the heatsink.
  5. Sony Vaio Fit 13A Heatsink + Fan Assembly Replacement: adım 5, 3 resimden 1. Sony Vaio Fit 13A Heatsink + Fan Assembly Replacement: adım 5, 3 resimden 2. Sony Vaio Fit 13A Heatsink + Fan Assembly Replacement: adım 5, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Use tweezers to carefully unplug the fan connector.
  6. Sony Vaio Fit 13A Heatsink + Fan Assembly Replacement, Remove the Fan: adım 6, 2 resimden 1. Sony Vaio Fit 13A Heatsink + Fan Assembly Replacement, Remove the Fan: adım 6, 2 resimden 2.
    • Use the Plastic Opening Tool to gently remove the heat sink and fan assembly from the computer.
    • Important: Follow the How to Apply Thermal Paste guide to replace the thermal paste before reassembling your device.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Marii
658 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 21-19, Maness Winter 2015 Cal Poly, Team 21-19, Maness Winter 2015 üyesi
CPSU-MANESS-W15S21G19
4 Üyeler
12 adet Kılavuz yazıldı
Bir Yorum
Could you also maybe do a tutorial on Sony Vaio Fit 13? http://www.laptoppartstore.com/replace--... Any luck figuring out how the fan may be detached and re-attached to the heatsink? Also, I notice a very specific type of taping... where can one procure those?
Abhishek D - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 9
Her zaman: 4,570
