Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
Common reasons for replacing the plastic casing are: controls on casing do not work, casing is cracked, or casing is scratched.
In this guide, you will learn how to replace the plastic casing for your device. Please remember to unplug the charging cable, since it could result in electric shock.
Neye ihtiyacın var
Remove one 5 mm Phillips #1 pan head screw, in the middle of the laptop, using a Bit Driver with Phillips PH1 bit.
Remove seven 5 mm Phillips #1 pan head screws with a Bit Driver, using a Phillips PH1 bit.
Bir başkası bu kılavuzu tamamladı.
