Ana içeriğe geç
Sony Xperia XA1 Audio Jack Replacement
Neye ihtiyacın var
  1. Sony Xperia XA1 Audio Jack Replacement, Phone Back Cover: adım 1, 3 resimden 1. Sony Xperia XA1 Audio Jack Replacement, Phone Back Cover: adım 1, 3 resimden 2. Sony Xperia XA1 Audio Jack Replacement, Phone Back Cover: adım 1, 3 resimden 3.
    • Using a hair dryer, apply heat evenly around the edges of the back of the phone. This will loosen the adhesive and allow you to remove the back panel.
    • As you're heating up the phone, begin to pry open the back starting from the middle, and going to the corners.
    • Do not apply heat in one area for too long.
  2. Sony Xperia XA1 Audio Jack Replacement, Audio Jack: adım 2, 3 resimden 1. Sony Xperia XA1 Audio Jack Replacement, Audio Jack: adım 2, 3 resimden 2. Sony Xperia XA1 Audio Jack Replacement, Audio Jack: adım 2, 3 resimden 3.
    • Use a Phillips #000 Screwdriver to remove the three 3 mm screws from the top bracket.
  3. Sony Xperia XA1 Audio Jack Replacement: adım 3, 3 resimden 1. Sony Xperia XA1 Audio Jack Replacement: adım 3, 3 resimden 2. Sony Xperia XA1 Audio Jack Replacement: adım 3, 3 resimden 3.
    • Use a spudger to gently pry the three tabs at the top of the phone and release the camera cover.
    • Gently lift the cover.
  4. Sony Xperia XA1 Audio Jack Replacement: adım 4, 3 resimden 1. Sony Xperia XA1 Audio Jack Replacement: adım 4, 3 resimden 2. Sony Xperia XA1 Audio Jack Replacement: adım 4, 3 resimden 3.
    • Use the Phillips #000 Screwdriver to remove the 3 mm screw to the left of the audio jack component.
    • Use an opening tool to lift the audio jack connector.
    • Pinch the connector and remove the audio jack.
Sonuç
Lindsey Taysom
205 İtibar
2 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 21
Her zaman: 204
