Ana içeriğe geç
Sony Xperia XA1 Rear Camera Replacement
Neye ihtiyacın var
  1. Sony Xperia XA1 Rear Camera Replacement, Phone Back Cover: adım 1, 3 resimden 1. Sony Xperia XA1 Rear Camera Replacement, Phone Back Cover: adım 1, 3 resimden 2. Sony Xperia XA1 Rear Camera Replacement, Phone Back Cover: adım 1, 3 resimden 3.
    • Using a hair dryer, apply heat evenly around the edges of the back of the phone. This will loosen the adhesive and allow you to remove the back panel.
    • As you're heating up the phone, begin to pry open the back starting from the middle, and going to the corners.
    • Do not apply heat in one area for too long.
  2. Sony Xperia XA1 Rear Camera Replacement, Rear Camera: adım 2, 3 resimden 1. Sony Xperia XA1 Rear Camera Replacement, Rear Camera: adım 2, 3 resimden 2. Sony Xperia XA1 Rear Camera Replacement, Rear Camera: adım 2, 3 resimden 3.
    • Use a Phillips #000 screwdriver to remove the three 3 mm screws near the top of the phone.
    • Use a spudger to gently pry the three tabs at the top of the phone.
  3. Sony Xperia XA1 Rear Camera Replacement: adım 3, 3 resimden 1. Sony Xperia XA1 Rear Camera Replacement: adım 3, 3 resimden 2. Sony Xperia XA1 Rear Camera Replacement: adım 3, 3 resimden 3.
    • Gently pry at the tabs until the cover comes free and is able to be removed.
    • Pull the piece up and set it aside. No cables are attached to the back.
  4. Sony Xperia XA1 Rear Camera Replacement: adım 4, 3 resimden 1. Sony Xperia XA1 Rear Camera Replacement: adım 4, 3 resimden 2. Sony Xperia XA1 Rear Camera Replacement: adım 4, 3 resimden 3.
    • Use an opening tool to release the back camera connector.
    • Gently pull the camera connector up to remove it.
    • Exercise caution when handling the rubber holder around the lens, as it can pop off easily.
Sonuç
sebastianh034
253 İtibar
3 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 20
Her zaman: 184
