Ana içeriğe geç
Sony Xperia XA1 Screen Replacement
Neye ihtiyacın var
    1. Sony Xperia XA1 Screen Replacement, Phone Back Cover: adım 1, 3 resimden 1. Sony Xperia XA1 Screen Replacement, Phone Back Cover: adım 1, 3 resimden 2. Sony Xperia XA1 Screen Replacement, Phone Back Cover: adım 1, 3 resimden 3.
      • Using a hair dryer, apply heat evenly around the edges of the back of the phone. This will loosen the adhesive and allow you to remove the back panel.
      • As you're heating up the phone, begin to pry open the back starting from the middle, and going to the corners.
      • Do not apply heat in one area for too long.
      FixBot'a Sor
      Yorum Ekle
    1. Sony Xperia XA1 Screen Replacement, Speaker: adım 2, 3 resimden 1. Sony Xperia XA1 Screen Replacement, Speaker: adım 2, 3 resimden 2. Sony Xperia XA1 Screen Replacement, Speaker: adım 2, 3 resimden 3.
      • Use a plastic opening tool to lift the battery connector.
      • Lift the flaps on both sides of the battery.
      FixBot'a Sor
      Yorum Ekle
    2. Sony Xperia XA1 Screen Replacement: adım 3, 3 resimden 1. Sony Xperia XA1 Screen Replacement: adım 3, 3 resimden 2. Sony Xperia XA1 Screen Replacement: adım 3, 3 resimden 3.
      • Pinch the pull tab at the bottom of the battery.
      • Gently lift the battery out.
      • Handle the battery with caution. It is very fragile.
      FixBot'a Sor
      Yorum Ekle
    3. Sony Xperia XA1 Screen Replacement: adım 4, 2 resimden 1. Sony Xperia XA1 Screen Replacement: adım 4, 2 resimden 2.
      • Use a Phillips #000 screwdriver to remove the four 3 mm screws that secure the bottom component.
      FixBot'a Sor
      Yorum Ekle
    4. Sony Xperia XA1 Screen Replacement: adım 5, 3 resimden 1. Sony Xperia XA1 Screen Replacement: adım 5, 3 resimden 2. Sony Xperia XA1 Screen Replacement: adım 5, 3 resimden 3.
      • Insert a spudger into the opening above the charging port, and apply gentle pressure to free the speaker piece.
      • Once the piece is loose, use your hand to remove the speaker from the phone.
      FixBot'a Sor
      Yorum Ekle
    1. Sony Xperia XA1 Screen Replacement, USB-C Module: adım 6, 3 resimden 1. Sony Xperia XA1 Screen Replacement, USB-C Module: adım 6, 3 resimden 2. Sony Xperia XA1 Screen Replacement, USB-C Module: adım 6, 3 resimden 3.
      • Locate the connecting cable and use a spudger or iFixit Opening Tool to remove the connector.
      • Disconnect the wifi/Bluetooth antenna wire, located at the top right of the USB-C charger board.
      FixBot'a Sor
      Yorum Ekle
    2. Sony Xperia XA1 Screen Replacement: adım 7, 3 resimden 1. Sony Xperia XA1 Screen Replacement: adım 7, 3 resimden 2. Sony Xperia XA1 Screen Replacement: adım 7, 3 resimden 3.
      • After removing the connector and antennas, you are able to pry the USB-C board using a plastic spudger.
      • Be cautious, little effort is required to lift up the board, if too much force is applied this could damage the board.
      FixBot'a Sor
      Yorum Ekle
    1. Sony Xperia XA1 Screen Replacement, Screen: adım 8, 3 resimden 1. Sony Xperia XA1 Screen Replacement, Screen: adım 8, 3 resimden 2. Sony Xperia XA1 Screen Replacement, Screen: adım 8, 3 resimden 3.
      • Using a spudger, carefully remove the thin copper piece attached to the motherboard.
      • This part is very easy to damage and can not be reused if damaged too much.
      FixBot'a Sor
      Yorum Ekle
    2. Sony Xperia XA1 Screen Replacement: adım 9, 3 resimden 1. Sony Xperia XA1 Screen Replacement: adım 9, 3 resimden 2. Sony Xperia XA1 Screen Replacement: adım 9, 3 resimden 3.
      • Carefully remove the front-facing camera with a spudger or your fingers.
      FixBot'a Sor
      Yorum Ekle
    3. Sony Xperia XA1 Screen Replacement: adım 10, 3 resimden 1. Sony Xperia XA1 Screen Replacement: adım 10, 3 resimden 2. Sony Xperia XA1 Screen Replacement: adım 10, 3 resimden 3.
      • Remove the single 3mm screw holding the audio jack using a Phillips #000 bit.
      • Using an iFixit Opening Tool, disconnect the audio jack from the motherboard.
      • Use a prying tool, such as a spudger, to remove the audio jack.
      FixBot'a Sor
      Yorum Ekle
    4. Sony Xperia XA1 Screen Replacement: adım 11, 3 resimden 1. Sony Xperia XA1 Screen Replacement: adım 11, 3 resimden 2. Sony Xperia XA1 Screen Replacement: adım 11, 3 resimden 3.
      • Disconnect the camera using an iFixit opening tool and remove it with your fingers.
      FixBot'a Sor
      Yorum Ekle
    5. Sony Xperia XA1 Screen Replacement: adım 12, 3 resimden 1. Sony Xperia XA1 Screen Replacement: adım 12, 3 resimden 2. Sony Xperia XA1 Screen Replacement: adım 12, 3 resimden 3.
      Bu adımda kullanılan alet:
      • Disconnect the two antennas from the motherboard using an iFixit opening tool or pair of tweezers.
      FixBot'a Sor
      Yorum Ekle
    6. Sony Xperia XA1 Screen Replacement: adım 13, 3 resimden 1. Sony Xperia XA1 Screen Replacement: adım 13, 3 resimden 2. Sony Xperia XA1 Screen Replacement: adım 13, 3 resimden 3.
      • Remove the SIM tray using your fingernail.
      • Using a spudger, remove the two connector tabs attached to the motherboard
      FixBot'a Sor
      Yorum Ekle
    7. Sony Xperia XA1 Screen Replacement: adım 14, 3 resimden 1. Sony Xperia XA1 Screen Replacement: adım 14, 3 resimden 2. Sony Xperia XA1 Screen Replacement: adım 14, 3 resimden 3.
      • Remove the single 3mm screw from the motherboard using a Phillips #000 bit.
      • Use a spudger to gently pry the motherboard free.
      FixBot'a Sor
      Yorum Ekle
    8. Sony Xperia XA1 Screen Replacement: adım 15, 3 resimden 1. Sony Xperia XA1 Screen Replacement: adım 15, 3 resimden 2. Sony Xperia XA1 Screen Replacement: adım 15, 3 resimden 3.
      • Peel the plastic battery tabs free.
      FixBot'a Sor
      Yorum Ekle
    9. Sony Xperia XA1 Screen Replacement: adım 16, 3 resimden 1. Sony Xperia XA1 Screen Replacement: adım 16, 3 resimden 2. Sony Xperia XA1 Screen Replacement: adım 16, 3 resimden 3.
      • Using a pair of angled tweezers, carefully remove the earpiece.
      • The ear piece is attached using a sticky adhesive
      FixBot'a Sor
      Yorum Ekle
    10. Sony Xperia XA1 Screen Replacement: adım 17, 3 resimden 1. Sony Xperia XA1 Screen Replacement: adım 17, 3 resimden 2. Sony Xperia XA1 Screen Replacement: adım 17, 3 resimden 3.
      • Using a pair of angled tweezers, carefully remove the small metal bracket from the top left side of the phone.
      FixBot'a Sor
      Yorum Ekle
    11. Sony Xperia XA1 Screen Replacement: adım 18, 3 resimden 1. Sony Xperia XA1 Screen Replacement: adım 18, 3 resimden 2. Sony Xperia XA1 Screen Replacement: adım 18, 3 resimden 3.
      • Remove the four 3mm silver screws located on the left side of the case using a Phillips #000 bit.
      • Once the screws are removed, unfold the side piece.
      FixBot'a Sor
      Yorum Ekle
    12. Sony Xperia XA1 Screen Replacement: adım 19, 3 resimden 1. Sony Xperia XA1 Screen Replacement: adım 19, 3 resimden 2. Sony Xperia XA1 Screen Replacement: adım 19, 3 resimden 3.
      • Using a pair of angled tweezers, remove the power and volume buttons.
      FixBot'a Sor
      Yorum Ekle
    13. Sony Xperia XA1 Screen Replacement: adım 20, 3 resimden 1. Sony Xperia XA1 Screen Replacement: adım 20, 3 resimden 2. Sony Xperia XA1 Screen Replacement: adım 20, 3 resimden 3.
      • Carefully remove the antennas.
      • Use a pair of tweezers if needed.
      FixBot'a Sor
      Yorum Ekle
    14. Sony Xperia XA1 Screen Replacement: adım 21, 3 resimden 1. Sony Xperia XA1 Screen Replacement: adım 21, 3 resimden 2. Sony Xperia XA1 Screen Replacement: adım 21, 3 resimden 3.
      • Remove the four 3mm silver screws from the right side of the phone using a Phillips #000 bit.
      • Once unfolded, peel the side piece from the phone, separating the glue that holds the two pieces together.
      FixBot'a Sor
      Yorum Ekle
    15. Sony Xperia XA1 Screen Replacement: adım 22, 3 resimden 1. Sony Xperia XA1 Screen Replacement: adım 22, 3 resimden 2. Sony Xperia XA1 Screen Replacement: adım 22, 3 resimden 3.
      • Remove the other side in the same manner.
      • All removeable components should be free, ready to be installed into your replacement screen.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Hunter
349 İtibar
2 adet Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 29
Her zaman: 967
