Ana içeriğe geç
Sony Xperia XA1 Speaker Replacement
Neye ihtiyacın var
  1. Sony Xperia XA1 Speaker Replacement, Phone Back Cover: adım 1, 3 resimden 1. Sony Xperia XA1 Speaker Replacement, Phone Back Cover: adım 1, 3 resimden 2. Sony Xperia XA1 Speaker Replacement, Phone Back Cover: adım 1, 3 resimden 3.
    • Using a hair dryer, apply heat evenly around the edges of the back of the phone. This will loosen the adhesive and allow you to remove the back panel.
    • As you're heating up the phone, begin to pry open the back starting from the middle, and going to the corners.
    • Do not apply heat in one area for too long.
  2. Sony Xperia XA1 Speaker Replacement, Speaker: adım 2, 3 resimden 1. Sony Xperia XA1 Speaker Replacement, Speaker: adım 2, 3 resimden 2. Sony Xperia XA1 Speaker Replacement, Speaker: adım 2, 3 resimden 3.
    • Use a plastic opening tool to lift the battery connector.
    • Lift the flaps on both sides of the battery.
  3. Sony Xperia XA1 Speaker Replacement: adım 3, 3 resimden 1. Sony Xperia XA1 Speaker Replacement: adım 3, 3 resimden 2. Sony Xperia XA1 Speaker Replacement: adım 3, 3 resimden 3.
    • Pinch the pull tab at the bottom of the battery.
    • Gently lift the battery out.
    • Handle the battery with caution. It is very fragile.
  4. Sony Xperia XA1 Speaker Replacement: adım 4, 2 resimden 1. Sony Xperia XA1 Speaker Replacement: adım 4, 2 resimden 2.
    • Use a Phillips #000 screwdriver to remove the four 3 mm screws that secure the bottom component.
  5. Sony Xperia XA1 Speaker Replacement: adım 5, 3 resimden 1. Sony Xperia XA1 Speaker Replacement: adım 5, 3 resimden 2. Sony Xperia XA1 Speaker Replacement: adım 5, 3 resimden 3.
    • Insert a spudger into the opening above the charging port, and apply gentle pressure to free the speaker piece.
    • Once the piece is loose, use your hand to remove the speaker from the phone.
Sonuç
Hunter
349 İtibar
2 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 23
Her zaman: 182
