Ana içeriğe geç
Sony Xperia XA1 USB-C Module Replacement
Neye ihtiyacın var
    1. Sony Xperia XA1 USB-C Module Replacement, Phone Back Cover: adım 1, 3 resimden 1. Sony Xperia XA1 USB-C Module Replacement, Phone Back Cover: adım 1, 3 resimden 2. Sony Xperia XA1 USB-C Module Replacement, Phone Back Cover: adım 1, 3 resimden 3.
      • Using a hair dryer, apply heat evenly around the edges of the back of the phone. This will loosen the adhesive and allow you to remove the back panel.
      • As you're heating up the phone, begin to pry open the back starting from the middle, and going to the corners.
      • Do not apply heat in one area for too long.
      FixBot'a Sor
      Yorum Ekle
    1. Sony Xperia XA1 USB-C Module Replacement, Speaker: adım 2, 3 resimden 1. Sony Xperia XA1 USB-C Module Replacement, Speaker: adım 2, 3 resimden 2. Sony Xperia XA1 USB-C Module Replacement, Speaker: adım 2, 3 resimden 3.
      • Use a plastic opening tool to lift the battery connector.
      • Lift the flaps on both sides of the battery.
      FixBot'a Sor
      Yorum Ekle
    2. Sony Xperia XA1 USB-C Module Replacement: adım 3, 3 resimden 1. Sony Xperia XA1 USB-C Module Replacement: adım 3, 3 resimden 2. Sony Xperia XA1 USB-C Module Replacement: adım 3, 3 resimden 3.
      • Pinch the pull tab at the bottom of the battery.
      • Gently lift the battery out.
      • Handle the battery with caution. It is very fragile.
      FixBot'a Sor
      Yorum Ekle
    3. Sony Xperia XA1 USB-C Module Replacement: adım 4, 2 resimden 1. Sony Xperia XA1 USB-C Module Replacement: adım 4, 2 resimden 2.
      • Use a Phillips #000 screwdriver to remove the four 3 mm screws that secure the bottom component.
      FixBot'a Sor
      Yorum Ekle
    4. Sony Xperia XA1 USB-C Module Replacement: adım 5, 3 resimden 1. Sony Xperia XA1 USB-C Module Replacement: adım 5, 3 resimden 2. Sony Xperia XA1 USB-C Module Replacement: adım 5, 3 resimden 3.
      • Insert a spudger into the opening above the charging port, and apply gentle pressure to free the speaker piece.
      • Once the piece is loose, use your hand to remove the speaker from the phone.
      FixBot'a Sor
      Yorum Ekle
    1. Sony Xperia XA1 USB-C Module Replacement, USB-C Module: adım 6, 3 resimden 1. Sony Xperia XA1 USB-C Module Replacement, USB-C Module: adım 6, 3 resimden 2. Sony Xperia XA1 USB-C Module Replacement, USB-C Module: adım 6, 3 resimden 3.
      • Locate the connecting cable and use a spudger or iFixit Opening Tool to remove the connector.
      • Disconnect the wifi/Bluetooth antenna wire, located at the top right of the USB-C charger board.
      FixBot'a Sor
      Yorum Ekle
    2. Sony Xperia XA1 USB-C Module Replacement: adım 7, 3 resimden 1. Sony Xperia XA1 USB-C Module Replacement: adım 7, 3 resimden 2. Sony Xperia XA1 USB-C Module Replacement: adım 7, 3 resimden 3.
      • After removing the connector and antennas, you are able to pry the USB-C board using a plastic spudger.
      • Be cautious, little effort is required to lift up the board, if too much force is applied this could damage the board.
      FixBot'a Sor
      Yorum Ekle
Sonuç
sebastianh034
253 İtibar
3 adet Kılavuz yazıldı
Ekip
1Rehber Yorum
thanks a lot, super clear, done everything in ~10 minutes
Eugene - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 9
Son 30 gün: 39
Her zaman: 832
