Ana içeriğe geç
Sony Xperia XA2 Ultra Speaker Replacement
Neye ihtiyacın var
  1. Sony Xperia XA2 Ultra Speaker Replacement, Rear Cover: adım 1, 2 resimden 1. Sony Xperia XA2 Ultra Speaker Replacement, Rear Cover: adım 1, 2 resimden 2.
    • Turn off your phone before continuing.
    • Remove the SIM card tray on the left side of the phone using a SIM card eject tool.
  2. Sony Xperia XA2 Ultra Speaker Replacement: adım 2, 1 resimden 1.
    • Heat the edge of the phone with the heat gun (recommended) for 30 seconds.
    • If you don't have a heat gun, a hair dryer can be used.
    • Use the hair dryer on the highest setting, constantly going around the phone to heat all of the edges.
    • The phone will become hot to the touch. Use gloves or a towel to touch the phone.
  3. Sony Xperia XA2 Ultra Speaker Replacement: adım 3, 2 resimden 1. Sony Xperia XA2 Ultra Speaker Replacement: adım 3, 2 resimden 2.
    • Apply the suction handle near an edge of the phone and pull upwards while trying to get an opening large enough for an iFixit opening pick.
  4. Sony Xperia XA2 Ultra Speaker Replacement: adım 4, 2 resimden 1. Sony Xperia XA2 Ultra Speaker Replacement: adım 4, 2 resimden 2.
    • Pry upwards with the pick to start pulling the rear cover off the adhesive it’s attached to.
    • Insert a second pick once there is enough room.
  5. Sony Xperia XA2 Ultra Speaker Replacement: adım 5, 2 resimden 1. Sony Xperia XA2 Ultra Speaker Replacement: adım 5, 2 resimden 2.
    • Take one of the picks and try to slide it down the side of the phone, pulling more of the cover off the adhesive.
    • The iFixit opening tool may also be used to gain better leverage.
    • The rear cover will pop off.
  6. Sony Xperia XA2 Ultra Speaker Replacement: adım 6, 1 resimden 1.
    • Once the rear cover is off, use the iFixit opening tool to detach the flex cable.
  7. Sony Xperia XA2 Ultra Speaker Replacement, Speaker: adım 7, 2 resimden 1. Sony Xperia XA2 Ultra Speaker Replacement, Speaker: adım 7, 2 resimden 2.
    • Remove the four 3 mm screws using a Phillips #000 screwdriver.
  8. Sony Xperia XA2 Ultra Speaker Replacement: adım 8, 2 resimden 1. Sony Xperia XA2 Ultra Speaker Replacement: adım 8, 2 resimden 2.
    • Using an iFixit opening tool, pry and remove the speaker.
Sonuç
Alyssa Bayles
879 İtibar
8 adet Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 25
Her zaman: 140
