Ana içeriğe geç
Sony Xperia Z1 Compact Back Cover Replacement
Kevin Bergstrom
Kevin Bergstrom ve 3 diğer katkıda bulunanlar
En son August 13, 2019 tarihinde güncellendi
2 dakika
Kolay
The back of the phone can become worn or cracked with continued use. This guide will show you how to remove the back cover of the device.
Neye ihtiyacın var
  1. Sony Xperia Z1 Compact Back Cover Replacement, Back Cover: adım 1, 1 resimden 1.
    • Heat along the edges of the back cover using a heat gun to soften the glue.
  2. Sony Xperia Z1 Compact Back Cover Replacement: adım 2, 1 resimden 1.
    • Attach the small suction cup to the back cover near the bottom of the phone.
    • Pull up on the suction cup and insert the plastic opening tool in between the back cover and the rest of the phone.
  3. Sony Xperia Z1 Compact Back Cover Replacement: adım 3, 2 resimden 1. Sony Xperia Z1 Compact Back Cover Replacement: adım 3, 2 resimden 2.
    • Move the spudger around the edge of the back cover to separate it from the black adhesive.
    • Separating the back cover from the rest of the phone ruins the adhesive which makes it no longer waterproof.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Kevin Bergstrom
383 İtibar
3 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 29
Son 30 gün: 30
Her zaman: 2,254
