Sony Xperia Z1 Compact Headphone Jack Replacement Replacement
Giriş
1. adıma gitThis guide will show you how you replace the headphone jack.
Neye ihtiyacın var
Heat along the edges of the back cover using a heat gun to soften the glue.
Carefully disconnect the battery from the logic board by using the plastic spudger as a lever.
Unscrew the four screws on the corners of the back frame using the JIS #00 screwdriver.
Remove the square rubber gasket from the camera using the plastic spudger.
To remove the headphone jack, cut the sticker between the headphone jack and the midframe with sharp tweasers.
