Ana içeriğe geç
Sony Xperia Z1 Compact Rear Camera Replacement
Kevin Bergstrom
Kevin Bergstrom ve 2 diğer katkıda bulunanlar
En son January 5, 2018 tarihinde güncellendi
Tahmin yok
Orta
This guide will replace the rear camera in the Sony Xperia Z1 Compact.
Neye ihtiyacın var
Parçalar
Aletler
Daha fazlasını göster…
iFixit bu bağlantılar üzerinden satın aldığınızda komisyon kazanır.
  1. Sony Xperia Z1 Compact Rear Camera Replacement, Back Cover: adım 1, 1 resimden 1.
    • Heat along the edges of the back cover using a heat gun to soften the glue.
  2. Sony Xperia Z1 Compact Rear Camera Replacement: adım 2, 1 resimden 1.
    • Attach the small suction cup to the back cover near the bottom of the phone.
    • Pull up on the suction cup and insert the plastic opening tool in between the back cover and the rest of the phone.
  3. Sony Xperia Z1 Compact Rear Camera Replacement: adım 3, 2 resimden 1. Sony Xperia Z1 Compact Rear Camera Replacement: adım 3, 2 resimden 2.
    • Move the spudger around the edge of the back cover to separate it from the black adhesive.
    • Separating the back cover from the rest of the phone ruins the adhesive which makes it no longer waterproof.
  4. Sony Xperia Z1 Compact Rear Camera Replacement, Battery: adım 4, 2 resimden 1. Sony Xperia Z1 Compact Rear Camera Replacement, Battery: adım 4, 2 resimden 2.
    • Carefully disconnect the battery from the logic board by using the plastic spudger as a lever.
  5. Sony Xperia Z1 Compact Rear Camera Replacement: adım 5, 2 resimden 1. Sony Xperia Z1 Compact Rear Camera Replacement: adım 5, 2 resimden 2.
    • Remove the single 1 x 3.0 mm screw holding the battery in using the JIS #00 screwdriver.
  6. Sony Xperia Z1 Compact Rear Camera Replacement: adım 6, 1 resimden 1.
    • Pry the battery up from the ends using the plastic spudger until the battery pops out of the enclosure.
  7. Sony Xperia Z1 Compact Rear Camera Replacement: adım 7, 1 resimden 1.
    • Remove the battery from the device
  8. Sony Xperia Z1 Compact Rear Camera Replacement, External Speaker: adım 8, 2 resimden 1. Sony Xperia Z1 Compact Rear Camera Replacement, External Speaker: adım 8, 2 resimden 2.
    • Unscrew the four screws on the corners of the back frame using the JIS #00 screwdriver.
  9. Sony Xperia Z1 Compact Rear Camera Replacement: adım 9, 3 resimden 1. Sony Xperia Z1 Compact Rear Camera Replacement: adım 9, 3 resimden 2. Sony Xperia Z1 Compact Rear Camera Replacement: adım 9, 3 resimden 3.
    • Wedge the plastic opening tool under the back frame. Move the plastic opening tool around the entire frame to separate it from the adhesive.
  10. Sony Xperia Z1 Compact Rear Camera Replacement: adım 10, 1 resimden 1.
    • Remove the back frame.
  11. Sony Xperia Z1 Compact Rear Camera Replacement: adım 11, 2 resimden 1. Sony Xperia Z1 Compact Rear Camera Replacement: adım 11, 2 resimden 2.
    • Wedge the spudger underneath the external speaker. Pull up on the external speaker using the spudger.
  12. Sony Xperia Z1 Compact Rear Camera Replacement: adım 12, 2 resimden 1. Sony Xperia Z1 Compact Rear Camera Replacement: adım 12, 2 resimden 2.
    • Remove the external speaker.
  13. Sony Xperia Z1 Compact Rear Camera Replacement, Motherboard: adım 13, 2 resimden 1. Sony Xperia Z1 Compact Rear Camera Replacement, Motherboard: adım 13, 2 resimden 2.
    • Remove the square rubber gasket from the camera using the plastic spudger.
  14. Sony Xperia Z1 Compact Rear Camera Replacement: adım 14, 2 resimden 1. Sony Xperia Z1 Compact Rear Camera Replacement: adım 14, 2 resimden 2.
    • Remove the black plastic corner still holding in the motherboard.
  15. Sony Xperia Z1 Compact Rear Camera Replacement: adım 15, 3 resimden 1. Sony Xperia Z1 Compact Rear Camera Replacement: adım 15, 3 resimden 2. Sony Xperia Z1 Compact Rear Camera Replacement: adım 15, 3 resimden 3.
    • Carefully pry up on the four sides of the motherboard using the plastic spudger til it separates from the base of the phone.
  16. Sony Xperia Z1 Compact Rear Camera Replacement: adım 16, 3 resimden 1. Sony Xperia Z1 Compact Rear Camera Replacement: adım 16, 3 resimden 2. Sony Xperia Z1 Compact Rear Camera Replacement: adım 16, 3 resimden 3.
    • Remove the motherboard from the device.
    • There may be a small yellow adhesive underneath the motherboard still holding it in. Slide the tip of the spudger through it to sever it.
  17. Sony Xperia Z1 Compact Rear Camera Replacement, Rear Camera: adım 17, 2 resimden 1. Sony Xperia Z1 Compact Rear Camera Replacement, Rear Camera: adım 17, 2 resimden 2.
    • Disconnect the camera from the motherboard using a spudger.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Kevin Bergstrom
383 İtibar
3 adet Kılavuz yazıldı
Ekip
Bir Yorum
The trouble is that the headphones jack and the monitor cables are unplugged when removing the motherboard and I do not think it is possible to plug them back in from the back side of the phone. I think the monitor needs to be removed for them to be plugged from the front.
natuk - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 21
Son 30 gün: 24
Her zaman: 940
