Ana içeriğe geç
Sony Xperia Z1s Charging Port Replacement
Neye ihtiyacın var
  1. Sony Xperia Z1s Charging Port Replacement, Battery: adım 1, 1 resimden 1.
    • Insert the opening pick in the crease between the rear cover and the body of the phone.
    • Pry along the edge to lift and remove the back cover.
  2. Sony Xperia Z1s Charging Port Replacement: adım 2, 1 resimden 1.
    • Using the T4 Torx screwdriver, remove five 5 mm screws from the panel above the battery.
    • Remove the panel by grabbing its bottom edge and lifting upwards.
  3. Sony Xperia Z1s Charging Port Replacement: adım 3, 1 resimden 1.
    • Use the opening pick to pry off the battery flex cable.
  4. Sony Xperia Z1s Charging Port Replacement: adım 4, 1 resimden 1.
    • Using the T4 Torx screwdriver, remove two 5 mm screws from the bottom corners of the battery.
  5. Sony Xperia Z1s Charging Port Replacement: adım 5, 1 resimden 1.
    • Firmly press the suction cup onto the battery.
    • Pull the battery out using the suction handle.
  6. Sony Xperia Z1s Charging Port Replacement, Motherboard: adım 6, 1 resimden 1.
    • Use the opening pick to pry off the camera flex cable.
    • Continue to lift the flex cable upward until the camera pops out.
  7. Sony Xperia Z1s Charging Port Replacement: adım 7, 1 resimden 1.
    • Use the opening pick to pry off the three flex cables on the bottom of the motherboard.
    • Do the same for the one flex cable at the top of the motherboard.
  8. Sony Xperia Z1s Charging Port Replacement: adım 8, 1 resimden 1.
    • Use the opening pick to pry off the black plastic cover above the top of the motherboard.
  9. Sony Xperia Z1s Charging Port Replacement: adım 9, 1 resimden 1.
    Bu adımda kullanılan alet:
    Satın Al
    • Use a pair of tweezers to lift up the motherboard.
    • If you are having trouble removing the motherboard, try lifting up the left edge first and sliding the rest of the motherboard out.
  10. Sony Xperia Z1s Charging Port Replacement: adım 10, 1 resimden 1.
    • Use a pair of tweezers to remove the pin connection on the motherboard.
    • Fully remove the motherboard from the device.
  11. Sony Xperia Z1s Charging Port Replacement, Charging Port: adım 11, 1 resimden 1.
  12. Sony Xperia Z1s Charging Port Replacement: adım 12, 1 resimden 1.
    Satın Al
    • Use a pair of tweezers to remove the charging port from the device.
Sonuç
Jacob Willey
85 İtibar
1 Kılavuz yazıldı
Ekip
Clemson, Team 4-4, Hunter Fall 2021 Clemson, Team 4-4, Hunter Fall 2021 üyesi
CLEM-HUNTER-F21S4G4
5 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 16
Her zaman: 166
