Ana içeriğe geç
Sony Xperia Z1s Rear Camera Replacement
Neye ihtiyacın var
  1. Sony Xperia Z1s Rear Camera Replacement, Rear Camera: adım 1, 1 resimden 1.
    • Insert the opening pick in the crease between the body of the phone and the phone's back cover.
    • Slide the opening pick around the crease until the back cover releases from the phone.
  2. Sony Xperia Z1s Rear Camera Replacement: adım 2, 1 resimden 1.
    • Using the T4 Torx screwdriver, remove the five 5 mm screws from the panel above the battery.
    • Remove the panel by grabbing its bottom edge and lifting upwards.
  3. Sony Xperia Z1s Rear Camera Replacement: adım 3, 1 resimden 1.
    • Use the opening pick to pry off the battery flex cable.
  4. Sony Xperia Z1s Rear Camera Replacement: adım 4, 1 resimden 1.
    • Use the opening pick to pry off the camera flex cable.
  5. Sony Xperia Z1s Rear Camera Replacement: adım 5, 1 resimden 1.
    • Use the opening pick to lift the camera out of the phone.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Amanda Simmons
148 İtibar
1 Kılavuz yazıldı
Ekip
Clemson, Team 4-4, Hunter Fall 2021 Clemson, Team 4-4, Hunter Fall 2021 üyesi
CLEM-HUNTER-F21S4G4
5 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 2
Son 30 gün: 11
Her zaman: 133
