Ana içeriğe geç
Sony Xperia Z2 Main Camera Replacement
Neye ihtiyacın var
Videoya Genel Bakış
  1. Sony Xperia Z2 Main Camera Replacement, Rear / Battery Cover: adım 1, 3 resimden 1. Sony Xperia Z2 Main Camera Replacement, Rear / Battery Cover: adım 1, 3 resimden 2. Sony Xperia Z2 Main Camera Replacement, Rear / Battery Cover: adım 1, 3 resimden 3.
    • Switch off the phone.
    • If you can't switch it off, you can use the OFF button near to the SIM card Tray.
    • Warm the Back Cover. You can use a hairdryer.
    • Be careful, the Back Cover is plastic.
  2. Sony Xperia Z2 Main Camera Replacement: adım 2, 3 resimden 1. Sony Xperia Z2 Main Camera Replacement: adım 2, 3 resimden 2. Sony Xperia Z2 Main Camera Replacement: adım 2, 3 resimden 3.
    • Use a small suction cup and plastic tools for separating the Rear panel.
    • There is Adhesive tape on the edges of the phone and some between the Battery and the Back Cover, as well. I found a small tab to pull just inside the top of the cover that removed the adhesive and released the back panel from the battery. Its that same style adhesive strip as used in the Iphone 5/5c/5s.
  3. Sony Xperia Z2 Main Camera Replacement: adım 3, 2 resimden 1. Sony Xperia Z2 Main Camera Replacement: adım 3, 2 resimden 2.
    • Before installing the new cover, you must clean the phone from the old adhesive tape and install a new one (if your spare part has come without double sided adhesive tape).
    Should include the information about the NFC antenna.
    Sounds like a dealbreaker for some people.
    Diogo Pinheiro - Yanıt
    What about it?
    Makos - Yanıt
  4. Sony Xperia Z2 Main Camera Replacement, Main Camera: adım 4, 2 resimden 1. Sony Xperia Z2 Main Camera Replacement, Main Camera: adım 4, 2 resimden 2.
Sonuç
9 farklı kişi bu kılavuzu tamamladı.
ZFix
194.171 İtibar
330 adet Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
326 Üyeler
1.672 adet Kılavuz yazıldı
7Kılavuz Yorumları
Where can I buy Spear main camera bucz my main camera is not functioning. Please help please... Please link me a website where I can buy it online.
Kushal maharjan - Yanıt
search ebay for "sony xperia z2 camera", unbelievable right?
deftoner -
I crashed my sony z2 and after i fix the screen i but the camera and it's overheated and doesn't work.what i must do and change
chris kat - Yanıt
I replied the comment to the other guy
deftoner -
My Camara get overheated too, and does not work, trying to replace it, where can I get it replace and how much does it go for thanks
Tripleboss - Yanıt
the camera have like a coil for do the focus, may be you short circuit it during the replace. There is 10 and 15 US replace camera from china at ebay. Try at fixez dot com
deftoner -
Hi, I replaced back camera in my Sony Xperia Z3c but it still doesn't work. It shows black screen. Do you think it's something which can be solved?
lucia.quitadamo - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 9,153
