Ana içeriğe geç
Sony Xperia Z4 Daughterboard Replacement
Neye ihtiyacın var
  1. Sony Xperia Z4 Daughterboard Replacement, Back Cover: adım 1, 1 resimden 1.
    • Before you begin, switch off your phone.
    • Apply a heated iOpener to the back of the phone to loosen the adhesive beneath the back cover. Apply the iOpener for at least two minutes.
  2. Sony Xperia Z4 Daughterboard Replacement: adım 2, 3 resimden 1. Sony Xperia Z4 Daughterboard Replacement: adım 2, 3 resimden 2. Sony Xperia Z4 Daughterboard Replacement: adım 2, 3 resimden 3.
    • Secure a suction handle to the bottom of the back cover, as close to the edge as possible.
    • Lift the back cover with the suction handle to create a small gap between the cover and the frame.
    • Insert an opening pick into the gap.
    • If you have trouble, apply more heat to further soften the adhesive. Follow the iOpener instructions to avoid overheating.
    • Slide the opening pick to the bottom left corner.
  3. Sony Xperia Z4 Daughterboard Replacement: adım 3, 2 resimden 1. Sony Xperia Z4 Daughterboard Replacement: adım 3, 2 resimden 2.
    • Insert a second opening pick and slide it to the bottom right corner to cut the adhesive.
    • Leave the opening picks in place to prevent the adhesive from resealing.
  4. Sony Xperia Z4 Daughterboard Replacement: adım 4, 3 resimden 1. Sony Xperia Z4 Daughterboard Replacement: adım 4, 3 resimden 2. Sony Xperia Z4 Daughterboard Replacement: adım 4, 3 resimden 3.
    • Insert a third opening pick at the bottom left corner.
    • In the next few steps whilst cutting around the rear camera make sure you only use the tip of the opening pick to avoid smearing the lens or damaging the camera.
    • Start to slide the tip of the opening pick from the bottom left corner along the side of the phone to cut the adhesive.
    • Leave the opening pick in its place at the top left corner to prevent the adhesive from resealing.
  5. Sony Xperia Z4 Daughterboard Replacement: adım 5, 2 resimden 1. Sony Xperia Z4 Daughterboard Replacement: adım 5, 2 resimden 2.
    • If the adhesive becomes hard to cut it most likely cooled down. Use your iOpener to reheat it.
    • Insert a fourth opening pick under the top left corner of the back cover.
    • Slide the opening pick along the top edge of the phone to cut the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
  6. Sony Xperia Z4 Daughterboard Replacement: adım 6, 2 resimden 1. Sony Xperia Z4 Daughterboard Replacement: adım 6, 2 resimden 2.
    • Insert a fifth opening pick at the top right corner of the phone.
    • Slide the opening pick along the right side to cut the remaining adhesive.
  7. Sony Xperia Z4 Daughterboard Replacement: adım 7, 2 resimden 1. Sony Xperia Z4 Daughterboard Replacement: adım 7, 2 resimden 2.
    • Lift and remove the back cover.
    • After installing the back cover, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond, such as by placing it under a stack of heavy books.
  8. Sony Xperia Z4 Daughterboard Replacement, Battery Disconnect: adım 8, 3 resimden 1. Sony Xperia Z4 Daughterboard Replacement, Battery Disconnect: adım 8, 3 resimden 2. Sony Xperia Z4 Daughterboard Replacement, Battery Disconnect: adım 8, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Use a pair of tweezers to carefully peel the adhesive strip off the mother board and the battery and remove it.
  9. Sony Xperia Z4 Daughterboard Replacement: adım 9, 2 resimden 1. Sony Xperia Z4 Daughterboard Replacement: adım 9, 2 resimden 2.
    • Use a pair of tweezers to peel the black adhesive strip off the battery connector and fold it out of the way.
  10. Sony Xperia Z4 Daughterboard Replacement: adım 10, 2 resimden 1. Sony Xperia Z4 Daughterboard Replacement: adım 10, 2 resimden 2.
    • Use a spudger to pry up and disconnect the battery connector.
  11. Sony Xperia Z4 Daughterboard Replacement, Battery: adım 11, 3 resimden 1. Sony Xperia Z4 Daughterboard Replacement, Battery: adım 11, 3 resimden 2. Sony Xperia Z4 Daughterboard Replacement, Battery: adım 11, 3 resimden 3.
    • Use a pair of tweezers and grab the pull tab at the top right corner of the battery.
    • Pull out the adhesive strip with a pair of tweezers.
    • Make sure you pull out the strip in a slow and steady motion and in a flat angle. To prevent the adhesive strip from ripping, it is helpful to twist the strip around the tweezers.
    • In case one of the adhesive strips rips and it’s not possible to pull it out completely, you can use high isopropyl alcohol (>90%) and/or a heated iOpener to loosen the adhesive. After the adhesive is soft enough use a prying tool such as an opening pick, a plastic/playing card or a spudger to carefully pry out the battery.
  12. Sony Xperia Z4 Daughterboard Replacement: adım 12, 3 resimden 1. Sony Xperia Z4 Daughterboard Replacement: adım 12, 3 resimden 2. Sony Xperia Z4 Daughterboard Replacement: adım 12, 3 resimden 3.
    • Repeat the previous process with the adhesive tab next to the battery flex cable.
  13. Sony Xperia Z4 Daughterboard Replacement: adım 13, 2 resimden 1. Sony Xperia Z4 Daughterboard Replacement: adım 13, 2 resimden 2.
    • Use an opening pick to pry the battery out of its recess until you can get a good grip.
  14. Sony Xperia Z4 Daughterboard Replacement: adım 14, 2 resimden 1. Sony Xperia Z4 Daughterboard Replacement: adım 14, 2 resimden 2.
    • Remove the battery.
    • Do not reinstall a damaged or deformed battery, as doing so is a potential safety hazard.
    • Remove any remaining adhesive from the midframe, and clean the glued areas with isopropyl alcohol and a lint-free cloth before applying new adhesive.
  15. Sony Xperia Z4 Daughterboard Replacement, Daughterboard with Cover: adım 15, 1 resimden 1.
    • Remove the Phillips #00 screw (3 mm length).
  16. Sony Xperia Z4 Daughterboard Replacement: adım 16, 2 resimden 1. Sony Xperia Z4 Daughterboard Replacement: adım 16, 2 resimden 2.
    • Use a pair of tweezers to peel off and remove the foam pad on top of the daughterboard.
  17. Sony Xperia Z4 Daughterboard Replacement: adım 17, 2 resimden 1. Sony Xperia Z4 Daughterboard Replacement: adım 17, 2 resimden 2.
    • Use a pair of tweezers to pry up and disconnect the antenna cable.
  18. Sony Xperia Z4 Daughterboard Replacement: adım 18, 2 resimden 1. Sony Xperia Z4 Daughterboard Replacement: adım 18, 2 resimden 2.
    • Use a spudger to pry up and disconnect the vibration motor connector.
  19. Sony Xperia Z4 Daughterboard Replacement: adım 19, 2 resimden 1. Sony Xperia Z4 Daughterboard Replacement: adım 19, 2 resimden 2.
    • Use the flat end of a spudger to pry up and disconnect the small main flex connector next to the vibration motor connector.
  20. Sony Xperia Z4 Daughterboard Replacement: adım 20, 3 resimden 1. Sony Xperia Z4 Daughterboard Replacement: adım 20, 3 resimden 2. Sony Xperia Z4 Daughterboard Replacement: adım 20, 3 resimden 3.
    • Lift the daughterboard cover using a pair of tweezers or a spudger by prying it up from its left side.
    • Remove the daughterboard cover carrying the daughterboard.
    • In case you only want to replace the daughterboard you can easily separate it from the plastic cover with an opening pick or a pair of tweezers.
Sonuç
If possible, turn on your phone and test your repair before installing new adhesive and resealing the phone.
Secure the battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the phone at the places where the old adhesive was located, not directly onto the battery. Press the new battery firmly into place.
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (+90%).
Dominik Schnabelrauch
230.529 İtibar
682 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
118 Üyeler
19.583 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 14
Her zaman: 491
