Ana içeriğe geç
Sphero Ollie LED Light Replacement
Neye ihtiyacın var
  1. Sphero Ollie LED Light Replacement, Tires and Hubcaps: adım 1, 1 resimden 1.
    • Firmly grasp Ollie in one hand.
    • Remove the blue rubber tire in a peeling motion with your opposite hand.
  2. Sphero Ollie LED Light Replacement: adım 2, 2 resimden 1. Sphero Ollie LED Light Replacement: adım 2, 2 resimden 2.
    • Continue to firmly hold Ollie in one hand.
    • Use a Plastic Opening Tool to gently pry off the hubcap.
    • Avoid inserting the Plastic Opening Tool into the empty holes, but instead use the tool near the tabs holding the hubcap in.
    • Do not aim the hubcap towards another person as it may pop off with force.
  3. Sphero Ollie LED Light Replacement, Motherboard: adım 3, 1 resimden 1.
    • Loosen and remove the 10mm screw on each side of the device using a JIS 1 screwdriver tip.
    • Remove the plastic tire frame from the device
  4. Sphero Ollie LED Light Replacement: adım 4, 2 resimden 1. Sphero Ollie LED Light Replacement: adım 4, 2 resimden 2.
    • Loosen and remove the four 10mm Screws on the underside of the device using a JIS 1 tip.
    • Firmly grasp the bottom of the device and pull the top half of the outer case off of the bottom.
  5. Sphero Ollie LED Light Replacement: adım 5, 2 resimden 1. Sphero Ollie LED Light Replacement: adım 5, 2 resimden 2.
    • Loosen and remove the 10mm screws holding the blue tooth connector as well as the two 1 10 screws holding the motherboard to the case using the JIS #1 screwdriver
    • Loosen and remove the 10mm screws holding the antenna to the case.
    • Gently remove mother board from the case with an upward motion.
  6. Sphero Ollie LED Light Replacement, LED Light: adım 6, 3 resimden 1. Sphero Ollie LED Light Replacement, LED Light: adım 6, 3 resimden 2. Sphero Ollie LED Light Replacement, LED Light: adım 6, 3 resimden 3.
    • Locate the first LED light by looking for the white plastic cover on the motherboard.
    • Flip the motherboard over, and locate the tabs holding on the plastic LED cover.
    • Pinch the tabs to the LED cover on the bottom side of the motherboard to remove the cover from the top side of the motherboard.
  7. Sphero Ollie LED Light Replacement: adım 7, 2 resimden 1. Sphero Ollie LED Light Replacement: adım 7, 2 resimden 2.
    • Locate the second LED light by looking for the perpendicular section on the motherboard with a matching LED light soldered to it.
    • Carefully de-solder the adhered edges on both LED lights to remove from from the motherboard.
    • Use great care when using a soldering iron.
    • For more detailed information on how to solder, please see our How to Solder and Desolder Connections guide
Sonuç
Krystal Hedrick
364 İtibar
3 adet Kılavuz yazıldı
Ekip
UW Tacoma, Team S1-G3, Rose Fall 2017 UW Tacoma, Team S1-G3, Rose Fall 2017 üyesi
UWT-ROSE-F17S1G3
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 11
Her zaman: 315
