Giriş
If Robot’s internal battery does not hold a charge, follow this guide to replace the battery. You will need a Size 00 Philips Screwdriver to complete replacement guide.
Neye ihtiyacın var
Set Spin Master Boxer on your workspace so that the bottom panel faces upwards.
Lift the top panel away from the main body of the robot to expose the yellow battery.
2 farklı kişi bu kılavuzu tamamladı.
3Kılavuz Yorumları
Any tips on where to buy a replacement battery?
In fact it’s easy, was able to put 1000 mah Lipo 952540 with a little stretching of battery plastic holder
can we replace boxer’s USB slot?
