Giriş
If Spin Master Boxer is not making any noises, follow this guide to replace speaker. The speaker is located inside of robot, and requires a Size 00 Philips Screwdriver to complete replacement, and requires soldering to remove the speaker.
Neye ihtiyacın var
Set Spin Master Boxer on your workspace so that the bottom panel faces upwards.
Using a Phillips #00 screwdriver, unscrew the two 3mm screws connecting the black speaker cover to the top panel.
Sonuç
