Ana içeriğe geç
Spy Net Ultra Vision Goggles Infrared Lights Replacement
Neye ihtiyacın var
  1. Spy Net Ultra Vision Goggles Infrared Lights Replacement, Open the Device: adım 1, 1 resimden 1.
    • Remove the six silver 11.4 mm Phillips #0 screws that hold the device shell in place.
    • Pry open the shell using the plastic opening tools if necessary. To do this, locate the groves running along the side of the entire device and wedge it open.
    FixBot'a Sor
    Yorum Ekle
  2. Spy Net Ultra Vision Goggles Infrared Lights Replacement, Remove the Infrared Lights: adım 2, 3 resimden 1. Spy Net Ultra Vision Goggles Infrared Lights Replacement, Remove the Infrared Lights: adım 2, 3 resimden 2. Spy Net Ultra Vision Goggles Infrared Lights Replacement, Remove the Infrared Lights: adım 2, 3 resimden 3.
    • Find the infrared light assemblies, which are located at the front end of the device on either side of the lens.
    • The process is the same regardless of which light you are replacing.
    • Lift the light assembly away from the rest of the device.
    FixBot'a Sor
    Yorum Ekle
  3. Spy Net Ultra Vision Goggles Infrared Lights Replacement, Open the Light Assembly: adım 3, 1 resimden 1.
    • Use the plastic opening tools to pry open the light assembly.
    FixBot'a Sor
    Yorum Ekle
  4. Spy Net Ultra Vision Goggles Infrared Lights Replacement, Disconnect the Lights: adım 4, 1 resimden 1.
    • Use the soldering iron and desoldering braid to de-solder the wires from the lights.
    • Check out This Guide for tips on soldering and de-soldering connections.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Travis Kempf
198 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 4-5, Brown Fall 2014 USF Tampa, Team 4-5, Brown Fall 2014 üyesi
USFT-BROWN-F14S4G5
3 Üyeler
12 adet Kılavuz yazıldı
1Rehber Yorum
thanks for the help
vincentarriesgado - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 12
Son 30 gün: 43
Her zaman: 1,359
