Ana içeriğe geç
Steam Deck OLED Left Thumbstick Removal
Clay Eickemeyer
Clay Eickemeyer
En son April 9, 2024 tarihinde güncellendi
Tahmin yok
Orta
Salt Önkoşul
Bu kılavuz yalnızca diğer kılavuzlar için bir ön koşul olarak kullanılmak üzere tasarlanmıştır. Tek başına eksiktir.
This guide demonstrates how to remove the left thumbstick in your Steam Deck OLED.
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
  1. Steam Deck OLED Left Thumbstick Removal, Prepare your Steam Deck for disassembly: adım 1, 3 resimden 1. Steam Deck OLED Left Thumbstick Removal, Prepare your Steam Deck for disassembly: adım 1, 3 resimden 2. Steam Deck OLED Left Thumbstick Removal, Prepare your Steam Deck for disassembly: adım 1, 3 resimden 3.
    • Turn on your Steam Deck and allow the battery to discharge below 25% before starting your repairs, as a charged lithium-ion polymer battery can be dangerous if accidentally punctured.
    • As an extra precaution, Valve recommends putting your Steam Deck into battery storage mode within the BIOS before starting any internal repairs. Read how to do that here.
    • Power down your Steam Deck and unplug any cables.
    • If you have a microSD card installed, make sure to remove it before opening the Steam Deck. If you attempt to remove the back cover with it still installed, it could snap right in half.
    • During your repair, it can be helpful at times to lay the Steam Deck face-down in its case to protect the thumbsticks and prevent wobble.
  2. Steam Deck OLED Left Thumbstick Removal, Remove the back cover screws: adım 2, 2 resimden 1. Steam Deck OLED Left Thumbstick Removal, Remove the back cover screws: adım 2, 2 resimden 2.
    Bu adımda kullanılan alet:
    FixMat
    $36.95
    • Use a T6 Torx driver to remove the eight 5.8 mm‑long screws securing the back cover.
  3. Steam Deck OLED Left Thumbstick Removal, Unclip a handle: adım 3, 3 resimden 1. Steam Deck OLED Left Thumbstick Removal, Unclip a handle: adım 3, 3 resimden 2. Steam Deck OLED Left Thumbstick Removal, Unclip a handle: adım 3, 3 resimden 3.
    • Insert an opening pick at an upward angle between the back cover and the front shell near one of the triggers.
    • If you can't insert your pick here, try along the top or bottom edges of the Steam Deck OLED before sliding it toward the handle.
    • Slide your pick along the edge of the handle to release the clips securing it to the front shell.
  4. Steam Deck OLED Left Thumbstick Removal, Unclip the top and bottom edges: adım 4, 3 resimden 1. Steam Deck OLED Left Thumbstick Removal, Unclip the top and bottom edges: adım 4, 3 resimden 2. Steam Deck OLED Left Thumbstick Removal, Unclip the top and bottom edges: adım 4, 3 resimden 3.
    • Reinsert your pick and slide it along the top and bottom edges until the back cover feels loose.
  5. Steam Deck OLED Left Thumbstick Removal, Remove the back cover: adım 5, 3 resimden 1. Steam Deck OLED Left Thumbstick Removal, Remove the back cover: adım 5, 3 resimden 2. Steam Deck OLED Left Thumbstick Removal, Remove the back cover: adım 5, 3 resimden 3.
    • Grip the unclipped handle and pull it away from the front shell to release the remaining clips.
    • Remove the back cover.
  6. Steam Deck OLED Left Thumbstick Removal, Disconnect the battery: adım 6, 3 resimden 1. Steam Deck OLED Left Thumbstick Removal, Disconnect the battery: adım 6, 3 resimden 2. Steam Deck OLED Left Thumbstick Removal, Disconnect the battery: adım 6, 3 resimden 3.
    • Grip the battery cable pull tab, located to the left of the battery.
    • Firmly pull the battery cable straight away from the motherboard shield (toward the battery) to disconnect it.
    • This bundled cable is fairly stiff. If you're having trouble, re-grip the pull tab close to the head of the connector and gently walk it side-to-side as you pull.
    • If the cable pull-tab feels fragile or rips during this process, remove the motherboard shield and disconnect the cable using a spudger.
    • When the battery cable comes free, it might push up on the motherboard shield. Don't worry, as this won't damage anything.
  7. Steam Deck OLED Left Thumbstick Removal, Disconnect the left thumbstick: adım 7, 3 resimden 1. Steam Deck OLED Left Thumbstick Removal, Disconnect the left thumbstick: adım 7, 3 resimden 2. Steam Deck OLED Left Thumbstick Removal, Disconnect the left thumbstick: adım 7, 3 resimden 3.
    • Use the point of a spudger to flip up the small locking flap on the left thumbstick ZIF connector.
    • The pull tab on this connector may be labeled TS.
    • Use tweezers or your fingers to grip the cable's pull tab and slide the connector straight out of its socket to disconnect it.
  8. Steam Deck OLED Left Thumbstick Removal, Disconnect the interconnect cable: adım 8, 3 resimden 1. Steam Deck OLED Left Thumbstick Removal, Disconnect the interconnect cable: adım 8, 3 resimden 2. Steam Deck OLED Left Thumbstick Removal, Disconnect the interconnect cable: adım 8, 3 resimden 3.
    • Use a spudger to flip up the small white locking flap on the left button board interconnect cable ZIF connector.
    • The pull tab on this connector may be labeled C‑L.
    • Use tweezers or your fingers to grip the cable's pull tab and slide it straight out of its socket to disconnect it.
  9. Steam Deck OLED Left Thumbstick Removal, Disconnect the left thumbstick: adım 9, 3 resimden 1. Steam Deck OLED Left Thumbstick Removal, Disconnect the left thumbstick: adım 9, 3 resimden 2. Steam Deck OLED Left Thumbstick Removal, Disconnect the left thumbstick: adım 9, 3 resimden 3.
    • Flip up the small black locking flap on the left thumbstick cable ZIF connector.
    • The pull tab on this connector may be labeled DB.
    • Slide the connector straight out of its socket to disconnect it.
  10. Steam Deck OLED Left Thumbstick Removal, Disconnect the D-pad: adım 10, 3 resimden 1. Steam Deck OLED Left Thumbstick Removal, Disconnect the D-pad: adım 10, 3 resimden 2. Steam Deck OLED Left Thumbstick Removal, Disconnect the D-pad: adım 10, 3 resimden 3.
    • Flip up the small locking flap on the D‑pad ZIF connector, located in the top right corner.
    • The pull tab on this connector may be labeled DPAD.
  11. Steam Deck OLED Left Thumbstick Removal, Disconnect the touchpad board: adım 11, 3 resimden 1. Steam Deck OLED Left Thumbstick Removal, Disconnect the touchpad board: adım 11, 3 resimden 2. Steam Deck OLED Left Thumbstick Removal, Disconnect the touchpad board: adım 11, 3 resimden 3.
    • Flip up the small locking flap on the touchpad board cable ZIF connector, located just below the previous one.
    • The pull tabs on the remaining ZIF connectors in this procedure may be labeled DB.
    • Lift the connector until its arms are free and slide it straight out to disconnect it.
  12. Steam Deck OLED Left Thumbstick Removal, Disconnect the left haptics: adım 12, 3 resimden 1. Steam Deck OLED Left Thumbstick Removal, Disconnect the left haptics: adım 12, 3 resimden 2. Steam Deck OLED Left Thumbstick Removal, Disconnect the left haptics: adım 12, 3 resimden 3.
    • If you aren't replacing your button board, you can leave this cable connected and lay the board over the right side of the frame after you've removed the screws.
    • Be careful when disconnecting the haptics, as the cables and connector are very delicate. Pry only on the base of the white connector and not on the cables or socket.
    • Insert the point of your spudger under the neck of the haptics cable connector.
    • Gently pry up to disconnect it.
  13. Steam Deck OLED Left Thumbstick Removal, Disconnect the left touchpad: adım 13, 3 resimden 1. Steam Deck OLED Left Thumbstick Removal, Disconnect the left touchpad: adım 13, 3 resimden 2. Steam Deck OLED Left Thumbstick Removal, Disconnect the left touchpad: adım 13, 3 resimden 3.
    • Flip up the small locking flap on the touchpad board cable ZIF connector, located just below the haptics connector.
  14. Steam Deck OLED Left Thumbstick Removal, Remove the left button board screws: adım 14, 1 resimden 1.
    • Use your T6 Torx driver to remove the four screws securing the left button board:
    • Two 5.9 mm‑long screws
    • One 3.8 mm‑long screw
    • One 4.9 mm‑long screw
  15. Steam Deck OLED Left Thumbstick Removal, Remove the left button board: adım 15, 3 resimden 1. Steam Deck OLED Left Thumbstick Removal, Remove the left button board: adım 15, 3 resimden 2. Steam Deck OLED Left Thumbstick Removal, Remove the left button board: adım 15, 3 resimden 3.
    • Insert the point of your spudger between the bottom right corner of the button board and the frame.
    • Pry up until you can grab the button board with your fingers.
    • Remove the button board.
    • During reassembly, make sure none of the five cables become trapped underneath the button board as you lay it into place.
  16. Steam Deck OLED Left Thumbstick Removal, Remove the left thumbstick screws: adım 16, 2 resimden 1. Steam Deck OLED Left Thumbstick Removal, Remove the left thumbstick screws: adım 16, 2 resimden 2.
    • Use your T6 Torx driver to remove the three 5.9 mm‑long screws securing the right thumbstick.
    • During reassembly, hold the Steam Deck OLED off your work surface so it doesn't rest on your thumbstick as you tighten the screws.
  17. Steam Deck OLED Left Thumbstick Removal, Remove the left thumbstick: adım 17, 3 resimden 1. Steam Deck OLED Left Thumbstick Removal, Remove the left thumbstick: adım 17, 3 resimden 2. Steam Deck OLED Left Thumbstick Removal, Remove the left thumbstick: adım 17, 3 resimden 3.
    • Grip the edges of the thumbstick board and rotate it counterclockwise to clear the trigger.
    • Remove the thumbstick.
Sonuç
Clay Eickemeyer
81.022 İtibar
455 adet Kılavuz yazıldı
Ekip
Guide Team Guide Team üyesi
Staff
9 Üyeler
11.338 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 11
Son 30 gün: 11
Her zaman: 25
