Ana içeriğe geç
SteelSeries Arctis Pro Plus GameDAC Secondary Button Replacement
Neye ihtiyacın var
  1. SteelSeries Arctis Pro Plus GameDAC Secondary Button Replacement, GameDAC Secondary Button: adım 1, 3 resimden 1. SteelSeries Arctis Pro Plus GameDAC Secondary Button Replacement, GameDAC Secondary Button: adım 1, 3 resimden 2. SteelSeries Arctis Pro Plus GameDAC Secondary Button Replacement, GameDAC Secondary Button: adım 1, 3 resimden 3.
    • Remove the plastic cover using the iFixit opening tool to pry the cover open.
    • Insert opening picks to keep the cover open as you work your way around the GameDAC.
    • Pop the cover off.
  2. SteelSeries Arctis Pro Plus GameDAC Secondary Button Replacement: adım 2, 2 resimden 1. SteelSeries Arctis Pro Plus GameDAC Secondary Button Replacement: adım 2, 2 resimden 2.
    • Remove the control wheel from the GameDAC by pulling on the knob.
  3. SteelSeries Arctis Pro Plus GameDAC Secondary Button Replacement: adım 3, 2 resimden 1. SteelSeries Arctis Pro Plus GameDAC Secondary Button Replacement: adım 3, 2 resimden 2.
    • Remove the five 6mm screws using the Phillips #0 driver head.
    • There is one screw hidden on the upper right-hand side of the display.
  4. SteelSeries Arctis Pro Plus GameDAC Secondary Button Replacement: adım 4, 2 resimden 1. SteelSeries Arctis Pro Plus GameDAC Secondary Button Replacement: adım 4, 2 resimden 2.
    • Hold the sides of the GameDAC and pull apart.
    • Don't pull the two sides apart quickly or forcefully to avoid tearing the wire connection between the two boards.
  5. SteelSeries Arctis Pro Plus GameDAC Secondary Button Replacement: adım 5, 1 resimden 1.
    • Remove the three 4mm screws from the circuit board using the Phillips #0 driver head.
  6. SteelSeries Arctis Pro Plus GameDAC Secondary Button Replacement: adım 6, 2 resimden 1. SteelSeries Arctis Pro Plus GameDAC Secondary Button Replacement: adım 6, 2 resimden 2.
    • Desolder the four button pins from the board to remove the button.
    • For help desoldering connections, follow this useful guide on How To Solder and Desolder Connections.
    • Use caution when soldering. The heated tip may cause damage to the board or burn you.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Kyle Chang
1.152 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team S18-G1, White Winter 2019 Cal Poly, Team S18-G1, White Winter 2019 üyesi
CPSU-WHITE-W19S18G1
4 Üyeler
21 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 16
Her zaman: 1,171
