Ana içeriğe geç
SuperSonic Matrix Mid SC-999 Battery Replacement
Neye ihtiyacın var
    1. SuperSonic Matrix Mid SC-999 Battery Replacement, Back Cover: adım 1, 1 resimden 1.
      • Wedge the plastic opening tool between the back cover of the device and the front panel.
      • You will hear a snapping sound as the cover is separated from the body of the device.
      FixBot'a Sor
      Yorum Ekle
    2. SuperSonic Matrix Mid SC-999 Battery Replacement: adım 2, 1 resimden 1.
      • Slide the opening tool along the seam between the front panel and the back cover to un-clip the remaining connections around the device.
      • Again, you will hear a snapping sound as the cover is separated from the body of the device.
      FixBot'a Sor
      Yorum Ekle
    3. SuperSonic Matrix Mid SC-999 Battery Replacement: adım 3, 2 resimden 1. SuperSonic Matrix Mid SC-999 Battery Replacement: adım 3, 2 resimden 2.
      • Lift the back cover from the body of the device to expose the internal components.
      FixBot'a Sor
      Yorum Ekle
    1. SuperSonic Matrix Mid SC-999 Battery Replacement, Battery: adım 4, 3 resimden 1. SuperSonic Matrix Mid SC-999 Battery Replacement, Battery: adım 4, 3 resimden 2. SuperSonic Matrix Mid SC-999 Battery Replacement, Battery: adım 4, 3 resimden 3.
      • Remove the Battery
      • The battery is secured to the back panel with tape and glue.
      • Peel back the tape around the battery and discard it.
      • Tear through the adhesive holding the battery by using the spudger tool.
      FixBot'a Sor
      Yorum Ekle
    2. SuperSonic Matrix Mid SC-999 Battery Replacement: adım 5, 3 resimden 1. SuperSonic Matrix Mid SC-999 Battery Replacement: adım 5, 3 resimden 2. SuperSonic Matrix Mid SC-999 Battery Replacement: adım 5, 3 resimden 3.
      • Desolder the 2 Battery Wires
      • The Battery has two wires connected to the motherboard (one black and one red).
      • If you're unfamiliar with soldering or desoldering check out this guide.
      • Be sure to wear protective eye wear. The soldering iron will become extremely hot and a potential danger, so make sure you are aware of your surroundings.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Collin Ferguson
176 İtibar
1 Kılavuz yazıldı
Ekip
Baylor, Team 6-1, Shaver Spring 2015 Baylor, Team 6-1, Shaver Spring 2015 üyesi
BU-SHAVER-S15S6G1
4 Üyeler
54 adet Kılavuz yazıldı
1Rehber Yorum
Link to the soldering technique guide!
Josh Lewis - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 38
Her zaman: 2,732
