Ana içeriğe geç
SuperSonic Matrix Mid SC-999 Battery Replacement
Neye ihtiyacın var
  1. SuperSonic Matrix Mid SC-999 Battery Replacement, Back Cover: adım 1, 1 resimden 1.
    • Wedge the plastic opening tool between the back cover of the device and the front panel.
    • You will hear a snapping sound as the cover is separated from the body of the device.
  2. SuperSonic Matrix Mid SC-999 Battery Replacement: adım 2, 1 resimden 1.
    • Slide the opening tool along the seam between the front panel and the back cover to un-clip the remaining connections around the device.
    • Again, you will hear a snapping sound as the cover is separated from the body of the device.
  3. SuperSonic Matrix Mid SC-999 Battery Replacement: adım 3, 2 resimden 1. SuperSonic Matrix Mid SC-999 Battery Replacement: adım 3, 2 resimden 2.
    • Lift the back cover from the body of the device to expose the internal components.
  4. SuperSonic Matrix Mid SC-999 Battery Replacement, Battery: adım 4, 3 resimden 1. SuperSonic Matrix Mid SC-999 Battery Replacement, Battery: adım 4, 3 resimden 2. SuperSonic Matrix Mid SC-999 Battery Replacement, Battery: adım 4, 3 resimden 3.
    • Remove the Battery
    • The battery is secured to the back panel with tape and glue.
    • Peel back the tape around the battery and discard it.
    • Tear through the adhesive holding the battery by using the spudger tool.
  5. SuperSonic Matrix Mid SC-999 Battery Replacement: adım 5, 3 resimden 1. SuperSonic Matrix Mid SC-999 Battery Replacement: adım 5, 3 resimden 2. SuperSonic Matrix Mid SC-999 Battery Replacement: adım 5, 3 resimden 3.
    • Desolder the 2 Battery Wires
    • The Battery has two wires connected to the motherboard (one black and one red).
    • If you're unfamiliar with soldering or desoldering check out this guide.
    • Be sure to wear protective eye wear. The soldering iron will become extremely hot and a potential danger, so make sure you are aware of your surroundings.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Collin Ferguson
176 İtibar
1 Kılavuz yazıldı
Ekip
Baylor, Team 6-1, Shaver Spring 2015 Baylor, Team 6-1, Shaver Spring 2015 üyesi
BU-SHAVER-S15S6G1
4 Üyeler
18 adet Kılavuz yazıldı
Bir Yorum
Link to the soldering technique guide!
Josh Lewis - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 12
Her zaman: 2,337
