Ana içeriğe geç
SuperSonic Matrix Mid SC-999 LCD Replacement
  1. SuperSonic Matrix Mid SC-999 LCD Replacement, Back Cover: adım 1, 1 resimden 1.
    • Wedge the plastic opening tool between the back cover of the device and the front panel.
    • You will hear a snapping sound as the cover is separated from the body of the device.
  2. SuperSonic Matrix Mid SC-999 LCD Replacement: adım 2, 1 resimden 1.
    • Slide the opening tool along the seam between the front panel and the back cover to un-clip the remaining connections around the device.
    • Again, you will hear a snapping sound as the cover is separated from the body of the device.
  3. SuperSonic Matrix Mid SC-999 LCD Replacement: adım 3, 2 resimden 1. SuperSonic Matrix Mid SC-999 LCD Replacement: adım 3, 2 resimden 2.
    • Lift the back cover from the body of the device to expose the internal components.
  4. SuperSonic Matrix Mid SC-999 LCD Replacement, Battery: adım 4, 3 resimden 1. SuperSonic Matrix Mid SC-999 LCD Replacement, Battery: adım 4, 3 resimden 2. SuperSonic Matrix Mid SC-999 LCD Replacement, Battery: adım 4, 3 resimden 3.
    • Remove the Battery
    • The battery is secured to the back panel with tape and glue.
    • Peel back the tape around the battery and discard it.
    • Tear through the adhesive holding the battery by using the spudger tool.
  5. SuperSonic Matrix Mid SC-999 LCD Replacement: adım 5, 3 resimden 1. SuperSonic Matrix Mid SC-999 LCD Replacement: adım 5, 3 resimden 2. SuperSonic Matrix Mid SC-999 LCD Replacement: adım 5, 3 resimden 3.
    • Desolder the 2 Battery Wires
    • The Battery has two wires connected to the motherboard (one black and one red).
    • If you're unfamiliar with soldering or desoldering check out this guide.
    • Be sure to wear protective eye wear. The soldering iron will become extremely hot and a potential danger, so make sure you are aware of your surroundings.
  6. SuperSonic Matrix Mid SC-999 LCD Replacement, Speaker: adım 6, 1 resimden 1.
    • Remove the Speakers
    • Use the tweezers to remove the speakers from their compartments.
  7. SuperSonic Matrix Mid SC-999 LCD Replacement: adım 7, 2 resimden 1. SuperSonic Matrix Mid SC-999 LCD Replacement: adım 7, 2 resimden 2.
    • Desolder the 4 Speaker Wires
    • These wires connect the speakers to the motherboard. They are the thinnest wires.
    • Be sure to wear protective eye wear. Also, keep in mind that the soldering iron will become extremely hot.
  8. SuperSonic Matrix Mid SC-999 LCD Replacement, Microphone: adım 8, 1 resimden 1.
    • Remove the microphone from its compartment.
    • The microphone is located toward the bottom left corner of the device (assuming the speakers are located on the right side of you).
  9. SuperSonic Matrix Mid SC-999 LCD Replacement: adım 9, 2 resimden 1. SuperSonic Matrix Mid SC-999 LCD Replacement: adım 9, 2 resimden 2.
    • Use the soldering iron to remove the wires connected to the microphone.
    • If you're unfamiliar with soldering or desoldering, check out this guide.
  10. SuperSonic Matrix Mid SC-999 LCD Replacement, FM Antenna: adım 10, 2 resimden 1. SuperSonic Matrix Mid SC-999 LCD Replacement, FM Antenna: adım 10, 2 resimden 2.
    • Use a soldering iron to desolder the region circled in red.
    • Be sure to wear protective eye wear. The soldering iron will become extremely hot and a potential danger, so be aware of your surroundings.
  11. SuperSonic Matrix Mid SC-999 LCD Replacement: adım 11, 2 resimden 1. SuperSonic Matrix Mid SC-999 LCD Replacement: adım 11, 2 resimden 2.
    • Desolder the FM antenna from the motherboard.
  12. SuperSonic Matrix Mid SC-999 LCD Replacement, Motherboard: adım 12, 2 resimden 1. SuperSonic Matrix Mid SC-999 LCD Replacement, Motherboard: adım 12, 2 resimden 2.
    • Remove the large ribbon cable from the socket that attaches it to the motherboard.
    • Pull down on the dark grey sliders located on both sides of the ribbon cable to release it.
  13. SuperSonic Matrix Mid SC-999 LCD Replacement: adım 13, 2 resimden 1. SuperSonic Matrix Mid SC-999 LCD Replacement: adım 13, 2 resimden 2.
    • Remove the small ribbon cable from the socket that attaches it to the motherboard.
    • Flip the dark grey latch to release the ribbon cable from the motherboard.
  14. SuperSonic Matrix Mid SC-999 LCD Replacement: adım 14, 3 resimden 1. SuperSonic Matrix Mid SC-999 LCD Replacement: adım 14, 3 resimden 2. SuperSonic Matrix Mid SC-999 LCD Replacement: adım 14, 3 resimden 3.
    • Remove the four Phillips #00 screws attaching the motherboard to the device.
  15. SuperSonic Matrix Mid SC-999 LCD Replacement, LCD: adım 15, 3 resimden 1. SuperSonic Matrix Mid SC-999 LCD Replacement, LCD: adım 15, 3 resimden 2. SuperSonic Matrix Mid SC-999 LCD Replacement, LCD: adım 15, 3 resimden 3.
    • Ensure that the motherboard and all other items are off before continuing.
    • Separate the screen and back housing by gently pulling on it.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Harris Dagha
866 İtibar
7 adet Kılavuz yazıldı
Dr Shaverz boyz Dr Shaverz boyz üyesi
Community
3 Üyeler
14 adet Kılavuz yazıldı
One Comment
what is the part number & where can I get a replacement screen for the SC-8809
impaired27 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 999
