Ana içeriğe geç
SuperSonic Matrix Mid SC-999 Speaker Replacement
Neye ihtiyacın var
  1. SuperSonic Matrix Mid SC-999 Speaker Replacement, Back Cover: adım 1, 1 resimden 1.
    • Wedge the plastic opening tool between the back cover of the device and the front panel.
    • You will hear a snapping sound as the cover is separated from the body of the device.
  2. SuperSonic Matrix Mid SC-999 Speaker Replacement: adım 2, 1 resimden 1.
    • Slide the opening tool along the seam between the front panel and the back cover to un-clip the remaining connections around the device.
    • Again, you will hear a snapping sound as the cover is separated from the body of the device.
  3. SuperSonic Matrix Mid SC-999 Speaker Replacement: adım 3, 2 resimden 1. SuperSonic Matrix Mid SC-999 Speaker Replacement: adım 3, 2 resimden 2.
    • Lift the back cover from the body of the device to expose the internal components.
  4. SuperSonic Matrix Mid SC-999 Speaker Replacement, Speaker: adım 4, 1 resimden 1.
    • Remove the Speakers
    • Use the tweezers to remove the speakers from their compartments.
  5. SuperSonic Matrix Mid SC-999 Speaker Replacement: adım 5, 2 resimden 1. SuperSonic Matrix Mid SC-999 Speaker Replacement: adım 5, 2 resimden 2.
    • Desolder the 4 Speaker Wires
    • These wires connect the speakers to the motherboard. They are the thinnest wires.
    • If you're unfamiliar with soldering or desoldering check out this guide.
    • Be sure to wear protective eye wear. Also, keep in mind that the soldering iron will become extremely hot.
Sonuç
Johncy George
101 İtibar
1 Kılavuz yazıldı
Ekip
Baylor, Team 6-1, Shaver Spring 2015 Baylor, Team 6-1, Shaver Spring 2015 üyesi
BU-SHAVER-S15S6G1
4 Üyeler
18 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 5
Her zaman: 303
