Ana içeriğe geç
Supercycle SC1800 Tire Replacement
Neye ihtiyacın var
  1. Supercycle SC1800 Tire Replacement, Tire: adım 1, 1 resimden 1.
    • Deflate the tire by pressing the valve stem in.
    • If it's difficult to press the stem in with your hands, use a plastic wedge tool.
  2. Supercycle SC1800 Tire Replacement: adım 2, 1 resimden 1.
    • Once the tire is deflated, press the beading inside until it is removed from the rim.
    • If you need to replace your rim, do it now.
  3. Supercycle SC1800 Tire Replacement: adım 3, 1 resimden 1.
    • Slide the plastic wedge tool under the beading of the tire, and pull it outwards.
    • The tool is not required, but it makes the job easier.
    • Once the tire is removed from the rim on one side, do the same to other side.
    • Make sure not to puncture the tire tube, as you will need that for the new tire.
  4. Supercycle SC1800 Tire Replacement: adım 4, 2 resimden 1. Supercycle SC1800 Tire Replacement: adım 4, 2 resimden 2.
    • Pull out the tire tube from the tire and transfer it into the new tire.
    • Make sure the valve is facing towards the center as shown in the second picture.
    • If you must replace your tire tube, do it now.
  5. Supercycle SC1800 Tire Replacement: adım 5, 1 resimden 1.
    • Once the tube is in place, use a little bit of force to get the beading into the rim, making sure the valve goes through the designated hole in the rim.
    • If it starts getting difficult to push the beading with your hands, use the plastic wedge tool to finish.
    • It is important for the valve to correctly line with the valve hole first. Otherwise, you risk damaging the tire tube.
  6. Supercycle SC1800 Tire Replacement: adım 6, 1 resimden 1.
    • Do the same to both sides of the beading. You will need to use the plastic tool for the other side.
  7. Supercycle SC1800 Tire Replacement: adım 7, 1 resimden 1.
    • Re-inflate the tire.
    • It may be difficult to re-inflate due to the folds in the deflated tire tube. Be patient!
Bitiş Çizgisi
Bir başkası bu kılavuzu tamamladı.
Firuz Khandakar
195 İtibar
1 Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 12
Her zaman: 1,132
