Ana içeriğe geç
Surface Studio Power Supply Unit Replacement
The Raptor
The Raptor ve 2 diğer katkıda bulunanlar
En son July 27, 2023 tarihinde güncellendi
20 - 30 dakika
Orta
Topluluk-Katkılı Kılavuz
Follow this guide to replace your power supply unit
Neye ihtiyacın var
Aletler
Daha fazlasını göster…
  1. Surface Studio Power Supply Unit Replacement, Power Supply Unit: adım 1, 3 resimden 1. Surface Studio Power Supply Unit Replacement, Power Supply Unit: adım 1, 3 resimden 2. Surface Studio Power Supply Unit Replacement, Power Supply Unit: adım 1, 3 resimden 3.
    • Lay the Surface face down on a padded surface
    • Be careful not to scratch the screen when laying it face down
    • Remove the four rubber feet at each corner concealing the Torx screws
    • Remove the four Torx screws under the rubber feet.
    • Two screws on the upper corners are longer than two screws on the lower corners.
    • Attach suction cups to the bottom cover and then pull on the suction cups to free the bottom cover.
  2. Surface Studio Power Supply Unit Replacement: adım 2, 2 resimden 1. Surface Studio Power Supply Unit Replacement: adım 2, 2 resimden 2.
    • Remove five torx screws holding the two fans to the midframe
    • Remove the two fans
    • The fan connectors are behind the midframe and not yet accessible. Let the fans hang loosely until you can access the connectors.
    • Four large torx screws and four small torx screws hold the midframe to the upper frame.
    • Remove four large torx screws holding the midframe
    • Remove four small torx screws holding the midframe
  3. Surface Studio Power Supply Unit Replacement: adım 3, 1 resimden 1.
    • Slowly remove the midframe
    • Be careful: the speaker on the midframe is still attached to the motherboard
    • Detach the connectors for the two fans and the speaker
  4. Surface Studio Power Supply Unit Replacement: adım 4, 3 resimden 1. Surface Studio Power Supply Unit Replacement: adım 4, 3 resimden 2. Surface Studio Power Supply Unit Replacement: adım 4, 3 resimden 3.
    • A screw retaining the power supply is under the hard drive so both the hard drive and the heat sink assembly must be removed
    • Remove four spring loaded torx screw labeled 1 to 4
    • Remove four torx screw labeled 5 to 7
    • Remove 5mm hex mounting post
    • Use a spudger to remove the heatsink assembly from the motherboard
  5. Surface Studio Power Supply Unit Replacement: adım 5, 2 resimden 1. Surface Studio Power Supply Unit Replacement: adım 5, 2 resimden 2.
    • Remove three torx screws holding the hard drive brackets
    • Remove the hard drive and disconnect the SATA/SATA power cable
  6. Surface Studio Power Supply Unit Replacement: adım 6, 2 resimden 1. Surface Studio Power Supply Unit Replacement: adım 6, 2 resimden 2.
    • Remove a Phillips screw still retaining the power supply
    • Remove a torx screw retaining the power supply cable
    • Unplug the power supply from the motherboard
    • Lift the power supply up and away from the base unit
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
The Raptor
6.276 İtibar
6 adet Kılavuz yazıldı
3Kılavuz Yorumları
Does anyone have a source for a new power supply?
AustinMike - Yanıt
Still no source fora power supply huh?
Steve - Yanıt
I recently purchased a MS Surface Studio 6th Generation computer and it seems that the USB ports don’t work properly and the headphone jack is dead…. Any ideas what I need to do to fix it before I send it back?
reowens - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 43
Her zaman: 4,318
