Ana içeriğe geç
Surfboard Traction Pad Replacement
Neye ihtiyacın var
  1. Surfboard Traction Pad Replacement, Traction Pad: adım 1, 2 resimden 1. Surfboard Traction Pad Replacement, Traction Pad: adım 1, 2 resimden 2.
    • Apply protective gloves.
  2. Surfboard Traction Pad Replacement: adım 2, 3 resimden 1. Surfboard Traction Pad Replacement: adım 2, 3 resimden 2. Surfboard Traction Pad Replacement: adım 2, 3 resimden 3.
    • Pull up the traction pad from the surfboard.
    • This allows for an easy start to cutting the adhesive.
  3. Surfboard Traction Pad Replacement: adım 3, 2 resimden 1. Surfboard Traction Pad Replacement: adım 3, 2 resimden 2.
    • Using a razor blade, cut away at the adhesive under the traction pad.
  4. Surfboard Traction Pad Replacement: adım 4, 2 resimden 1. Surfboard Traction Pad Replacement: adım 4, 2 resimden 2.
    • Completely remove each section of the traction pad leaving only excess adhesive.
  5. Surfboard Traction Pad Replacement: adım 5, 3 resimden 1. Surfboard Traction Pad Replacement: adım 5, 3 resimden 2. Surfboard Traction Pad Replacement: adım 5, 3 resimden 3.
    • Apply adhesive remover to the paper towels.
    • Apply the paper towels to the section of the board with excess adhesive until it is covered.
    • Let it stand for 5 minutes.
  6. Surfboard Traction Pad Replacement: adım 6, 3 resimden 1. Surfboard Traction Pad Replacement: adım 6, 3 resimden 2. Surfboard Traction Pad Replacement: adım 6, 3 resimden 3.
    • Remove the paper towels from the board.
    • Cut away the rest of the excess adhesive.
    • Dry the board with paper towels.
Sonuç
Now the tail of your board is clean and ready for a new traction pad.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 466
